Waxx
I did not check the design in detail, but those woofer drivers can also be used without a horn. It's even better when using them for hifi i spaces that are small compared to the movie theaters where they where ment for. Many use Onken or Atec 620 cabinet and the smaller multicellhorns or newer JBL Horns for the top as they fit better in smaller spaces, even with the same drivers as the big VOTT systems. What he is using i don't know and i hardly care.The problem with the speakers he is building is that none of them follow the intent of the original Altec engineers when they developed the VOTT systems. Specifically, using a huge, very wide dispersion horn designed for huge movie theaters of the mid-century and before which is capable of covering way up into balconies and a driver which was designed to produce enough energy to accomplish that. That horn/driver combination mated to a small bass reflex cabinet which is nowhere capable of keeping up with the sensitivity of the HF components.
In other words, the HF and LF are grossly mismatched. On top of that, the original VOTT systems used a short LF horn so that time alignment between HF and LF was automatically accomplished by virtue of the driver's voice coils being on the same vertical plane. Below is the A-4 system which shows how these components were intended to be configured:
The smaller A-7 and A7-500 were designed for smaller theaters, motion picture studio preview rooms, and homes with a lot of space. Below is the A7-500 (mine actually).
Altec did make a couple systems which used the huge multi-cellular horn with non-LF horns, the A-9 and A-10, but these were designed for special circumstances of very shallow spaces behind the screen of the "shoebox" theaters of the 70s, and were frankly a severe compromise.
What this guy is making conforms to none of how the original designers intended these components be used. Now I'm sure someone here is going to bitch and say that I'm just being an old purist, and to some degree that is correct. But being an ex-Altec engineer and seeing the components be used more as pandering to style and in systems which are going to sound like the worst that the components are capable of - I need to call bullshit.
This guy will have his museum show and have his 15 minutes of fame, and then he'll go back to making skateboards or whatever he did before. And the people who build these systems for real will go on laboring behind the scenes.
I would never buy his products as they are way overpriced and i can make the same for way less (and probally better engineered). My setup uses Faital and Beyma drivers and a JBL 2380 clone horn. Those are technically better fit for small pa (garden parties) like the future owner wants. I did already build a similar set (but all Faital drivers) for someone else.
