- Joined
- May 11, 2025
- Messages
- 207
- Likes
- 162
I read his procedure, you made the assumption.Archimago is a nice guy. Feel free to contact him directly via his webpage and clarify, instead of assuming.
Transparent for practical purposes. Not guaranteed transparent in every imaginable test. Like I already said.Actually, what is it now? Transparent? Not transparent?
Already familiar, thanks. Not sure if you are. If you have a point, demonstrate it. You're the one who said that Archimago's article proved that high res audio is audibly distinctive from 16 bit audio. Being honest, I can't see where I made an argument from authority...https://en.wikipedia.org/wiki/Argument_from_authority . Read it thoroughly, and be honest to yourself.
Basic logic - if there is one person able to distinguish A from B it means A from B can be distinguished. No bias here.Wow, 'proved', hey? Your biases are easily confirmed! And the way you frame it as "the difference was clearly audible", is highly misleading. What I think you meant to say, is "there appear to be a few outlier people who can tell them apart, but most of us cannot."
And also, we have to allow for the odd person with special hearing abilities. It's not impossible. Mutation is a thing, right? Right?? (Those who deny evolution are excused from answering!)
Not what you said here, using argument from authority. “industry and academia”, You said TRANSPARENT and INAUDIBLE. You did not state TRANSPARENT FOR PRACTICAL PURPOSES.Transparent for practical purposes. Not guaranteed transparent in every imaginable test. Like I already said.
The best way to keep one's hat on is to remember that lossy compression is effectively inaudible above a certain bitrate. Atmos audio at 768 kbps is considered transparent within the industry and academia.
Again, instead of running in circle, reach to Archimago. Takes the same time as to post here.I read his procedure, you made the assumption.
...and neither am I.E.g. I was shopping for new projector recently, had native 4K projector before and was hell bent that nothing else will do. Had Epson pixel shifter for a weekend, and compared it to SIM2 and realized that I am fooling myself, and I could not really distinguish in terms of resolution [there were differences elsewhere, but not enough to pay 3x the price]. I am now not running around and explaining to everybody with native 4K projectors that they are idiots for buying 4K native, just because I can not distinguish it.
No disagreement here, above certain rate, for sure, not only effectively but probably absolutely. One could argue that as long as you do not have original ADM file, even TrueHD is not “100% lossless”.See that word of mine, effectively?
We already know that about 1/3 reported no audible preference above so it's no surprise that on a 0-10 scale where 0 is "no difference" and 10 is "obvious difference", it would be skewed towards 0
In this AB testing, four people scored 10/10, so the difference was clearly audible.
Not only will I ask which sample sounded "better" (knowing that one of the samples is the hi-res 24-bit source), it's also important to indicate "no difference" if that's what you perceived and have that perception counted.
I'll also ask how much difference you heard - so if you're very confident, rate this as 10/10 ("obvious audible difference"). Optionally, you can also tell me what seemed to have changed if a difference was audible - noise floor, bass quality/amount, soundstage change, perceived resolution, etc...
good guide for starting your journey in ABX testing and understanding what was going in that specific test. I trust you are now able to connect the dots properly, as I think you were missing this part of information.
Hi Milan,
As you can imagine, as a blind test distributed over the Internet, I would not be able to properly keep it blind unless the music were wrapped in some kind of player software; which would mean certain computer testing only, and we can't sent the audio to playback devices. If I gave a Sample C which is known to be 24-bits to compare, then some could even inadvertently notice that 2 files are of the exact same size, thereby there's your answer...
I think choosing which one "sounds better" is fine because much of the time these days we're just streaming whatever version is on the service or whatever version we bought as a hi-res download without assurance that a 16-bit CD version was derived from that exact mastering.
Ah yes, that's the problem. How you define 'better'
Some would say that it depends on your subjective view.
But some would say that better is the one which is closer to the truth - in this case to the original 24bit file
But how can you know what was original when you don't have a reference point.
as I said better can be tricky word.
ps. maybe next time we should be doing something like three files. File A - 16bits File B - 24bits (original) and File C - original 24bits file marked clearly. Then we can try which file from A/B is original one and if people can hear that.
Anyway as always thanks for the work you are doing.
1. Download this file (there's a download icon top right of the page to grab the ZIP):
Inside you will find 2 samples of "Giorgio by Moroder" from Random Access Memories (Sample A and B). It's a good track I think because of the diversity you'll find over the 2.5-minute segment I selected. There's the sound of the natural spoken voice, some subtle background audio (sort of like the incidental noises on Jazz At The Pawnshop), and in the latter half of the sample, you'll hear heavier beats with good bass.
I think the 2.5 minute sample should be enough to hear significant or even subtle differences. To keep download size small, I downsampled the original 24/88.2 official hi-res download to 24/44.1kHz using an excellent resampler. This was done before dithering the file to 16/44.1 to create the 16-bit sample. Regardless of whether you believe 88.2kHz sounds much different from 44.1kHz, any audible differences between the 2 samples would still be a result of the bit-depth reduction and dithering.
To maintain the blinded condition, both samples are presented as 24-bit FLAC (even though one of them contains 16-bit dithered content) to feed your DAC in case that's a source of sonic difference. As usual with my Internet Blind Tests, various "honesty control" mechanisms were implemented to reduce the chance of bias as much as I could without compromising the 24-bit quality compared to dithered 16-bit resolution. All details will be revealed after the data has been collected. It's a listening test so please try to refrain from running the samples thru analyzers and audio editors.
Please ask Archimago directly, whether he has received any foobar ABX 10/10 results, This will hopefully end the circle of assumptions and interpretations.Then show that Fidji. Archimago states this about the test:
There is literally no need. He explained his procedure quite clearly on his webpage. I took the time to read the procedure and to understand where his reported numbers came from.Again, instead of running in circle, reach to Archimago. Takes the same time as to post here.
and yet, there are people, that have proven ability to discern 16 bit vs Hi-Res.
RESULTS: Internet Blind Test of 24-Bit vs. Dithered 16-Bit Part Deux - Daft Punk Edition
A blog for audiophiles about more objective topics. Measurements of audio gear. Reasonable, realistic, no snakeoil assessment of sound, and equipment.archimago.blogspot.com
BTW, you need to do it with proper neutral headphones and it is just “look how I can juggle 3 balls, while standing on 1 foot” type of useless ability, no way to make money from it. 100% proper mastering trumps any resolution difference and here most of the best digital variants/masterings are 16bit CD mixes before Loudness War. Beats “Remastered HiRes” every time on SQ
And re DD+ vs TrueHD - here it gets even more contentious, but it needs to be said - you need to have a proper gear. Period. Luckily we have industry standard in form of CEDIA RP22 https://cedia.org/site/assets/files/6057/cedia-cta_rp22_v1_2_sept_2023.pdf#page89
You need to be on Performance Level 3 Minimum, ideally with as much as possible parameters making it to Level 4. With 5.1.2 in living room you do not need to even bother and you can enjoy thousands of songs available on Apple Music as you are more than good with DD+ and 768kbps. So yes, for most of the people it will be the same and for lot of the source material it will be irrelevant as it does not make use of full TrueHD bandwith.
With right setup and once you get to something like this in terms of source material - extensive use of objects, dense mix, lot of layers of sound, then the limits of lossy compressed DD+ are clearly audible, as it truncates objects. You can even observe difference on such crude metrics as Dynamic Range between DD+ and TrueHD version. 2 attached pictures are same track, one DD+ on Apple Music and the other one TrueHD from BR Audio.
I do not like subjective descriptors, but the term I would use as differentiator is “resolution” - ability to clearly pick up more instruments in parallel. It also usually results in more dynamic presentation, subjectively. And before somebody asks - yes I have tried blind testing. with 10/10 result.View attachment 476823View attachment 476824
As streamers was asked for and got with CD (16/44 or better), I don't think the BluRay equivalent of Dolby TrueHD streamed data is too much to ask for.Transparent for practical purposes. Not guaranteed transparent in every imaginable test. Like I already said.
Hey, I think know that guy. Didn't he used to write for TAS, then went to Stereophile, and has now moved back to TAS ?"My hearing is extremely superior to anything humans can imagine", and "My lineup is extremely beyond anything that people can even imagine", and "The differences are huge. It's like comparing a VW versus a Ferrari."
I've been unable to find any believable tests of this. Can you refer me to any ABX or other blinded tests that show this difference?<snip>
For me, lossy DD+ versus TrueHD isn’t even a close call — the difference is obvious, not subtle. It’s the same as comparing Netflix “4K” to a proper UHD/Kaleidescape: both might be labeled 4K, but it is different 4K.. That’s why, while I don’t see any reason to pay extra for hi-res stereo, it still makes perfect sense to pay a premium for lossless Atmos or multichannel audio. The jump in quality is real and easy to hear.
<snip
I think in this case he is hearing something, but it has nothing to do with lossless vs lossy or bit rates. We are likely dealing with different masterings or some other difference in this soundtrack. I've definitely noticed that movies I have on Blu-ray often sound better than the same movie from a streaming service.I've been unable to find any believable tests of this. Can you refer me to any ABX or other blinded tests that show this difference?
It's been shown repeatedly and conclusively that sighted tests are not valid.
There was a discussion here a couple of years ago with a couple of guys from the industry. They described a "home" mix that they made that was distinct from the theatrical release. It would not surprise me if there were also a streaming mix that could potentially be different for each platform because they all have different requirements.I think in this case he is hearing something, but it has nothing to do with lossless vs lossy or bit rates. We are likely dealing with different masterings or some other difference in this soundtrack. I've definitely noticed that movies I have on Blu-ray often sound better than the same movie from a streaming service.
My assumption has generally been that some kind of compression is being applied, but I haven't seen any actual evidence.
Same thing was thought ages ago with the DD soundtrack on Laserdisc vs the same thing on DVD. The LD mixes seemed to have wider dynamics and just be more demanding overall.I think in this case he is hearing something, but it has nothing to do with lossless vs lossy or bit rates. We are likely dealing with different masterings or some other difference in this soundtrack. I've definitely noticed that movies I have on Blu-ray often sound better than the same movie from a streaming service.
I agree that lossy audio at 'sufficient' bitrates (ie the high range of normal: 320 kbps for stereo, 768 kbps for Atmos) is still not a guarantee that it would be completely indistinguishable from lossless in every way. But the way lossy artefacts manifest, if the bitrate is 'sufficient', is in the odd moment in a recording, not in the overall sound of the music itself. Yes, I am happy to say as a perfectionist, we don't want that 'odd moment'. But honestly, enjoying it less is unnecessary if the only perceivable differences are in the odd moment.
And, since the real issue to which I was responding is the complaints of using lossy codecs for Atmos streaming, perhaps those complainants can post some valid (academic or other) evidence of the audible problem.
I can only speak for myself, but I would prefer some evidence that there's an audible difference between lossy and lossless before making demands that streaming services spend additional bandwidth (which is not an infinite resource).Why wouldn't we do the same for multichannel?
Why, did you do the same for 2ch or is it only that you have no interest in multich?I can only speak for myself, but I would prefer some evidence that there's an audible difference between lossy and lossless before making demands that streaming services spend additional bandwidth (which is not an infinite resource).
But here we all agree that sighted bias is a very real thing, once you know, you know. No one is above the influence of the bias.
So having known degradation of the supplied source can absolutely make for a less enjoyable experience for the learned listener.
It probably will, Sal, it probably will. But it might not be the same price. And then the point of it comes into question, are you just lining the pockets of the middlemen for no perceptual reward?I've very surprised anyone here would support the use of lossy compression when its mainly unnecessary.
I oft remember folks debating the audibility of compression rates by 2ch streamers but no one saying "OH, but that's OK, just carry on".
We of the "audiophile cult" complained and complained till change was mostly effected 3-4 years ago.
