The mixer of course can do whatever he or she wants. Just that not everything makes sense and/or give good results. So you can't place the sound at the direction you want using no more than 2 channels?
For sure, the general state of LP pressings back in the 70s and going forward was mostly horrid. We would spend tons of money buying 2, 3, 4 copies trying to get one with a halfway quiet surface and no other flaws, then searching out imports and later MFSL to find anything just a little bit better..Guess what guys? Bad mixing and mastering has plagued the recorded music space in every format and every era. Being amazed and shocked to see examples....is naive.
Fortunately, good and great mixing and mastering has blessed us at the same time.
They are rationalizing their setups.
Five full-range speakers in a circle around you is not ideal. Each one of those speakers would be strongly interacting with the room boundaries very differently, and each would therefore have a different frequency response. The ideal setup would be compact speakers capable of high SPL crossed over to multiple subs at 80Hz. This would result in superb imaging and an even bass frequency response throughout the room.It's not about "striving", it's called "compromising". The ideal speaker setup would be full range speakers in a complete hemisphere around you. Maybe some in the floor too for good measure. Anything short of that is compromising.
Five? I meant enough speakers to completely fill the hemisphere around you. Obviously this would require careful mixing to avoid interference between all the speakers, but I believe this is something that has actually been done, more or less.Five full-range speakers in a circle around you is not ideal. Each one of those speakers would be strongly interacting with the room boundaries very differently, and each would therefore have a different frequency response. The ideal setup would be compact speakers capable of high SPL crossed over to multiple subs at 80Hz. This would result in superb imaging and an even bass frequency response throughout the room.
You still don't need a bunch of towers around you to accomplish this. A bunch of bookshelf speakers would be just as good, and you wouldn't have to work so hard to get them properly integrated with the subwoofers.Five? I meant enough speakers to completely fill the hemisphere around you. Obviously this would require careful mixing to avoid interference between all the speakers, but I believe this is something that has actually been done, more or less.
All bass in movie soundtracks is mono. While there are interaural time difference down to 20Hz, the ability to hear it becomes weak below 80Hz. There is also interaural level difference, but they are also weak at low frequencies as a result of the long wavelengths of bass frequencies. Recording stereo bass is a waste of time because of these reasons.I don't know where this believe, that bass in mono was something to strive for, comes from. Or that professional setups would work with bass in mono.
Movement in the bass is fun and is sounding great!
How do you handle this horrid bass problem in a stereo only system ?Five full-range speakers in a circle around you is not ideal. Each one of those speakers would be strongly interacting with the room boundaries very differently, and each would therefore have a different frequency response. The ideal setup would be compact speakers capable of high SPL crossed over to multiple subs at 80Hz. This would result in superb imaging and an even bass frequency response throughout the room.
Much the same way as you would handle a multichannel system. Place the subs where they perform the best, and place the stereo speakers where they perform the best.How do you handle this horrid bass problem in a stereo only system
This is leaning more towards mid bass, not actual bass frequencies.....and "movement in the bass" is still easily achieved using frequencies 80 Hz and up!
Sure, but because bass instruments tend to have lots of harmonics, which go to the mains, it's easy to make them 'walk about'.This is leaning more towards mid bass, not actual bass frequencies.
Sounds just like I have with my 5 full rangeMuch the same way as you would handle a multichannel system. Place the subs where they perform the best, and place the stereo speakers where they perform the best.
Those harmonics are in the midrange, so it is the midrange that "walks about", not the bass.Sure, but because bass instruments tend to have lots of harmonics, which go to the mains, it's easy to make them 'walk about'.
The research done on 5 full-range speakers in a room does not support this, but it is good to dream.Sounds just like I have with my 5 full range![]()
Psycho-acoustically? I think a fundamental and its harmonics can be heard as an integrated sound.Those harmonics are in the midrange, so it is the midrange that "walks about", not the bass.
At 80Hz, your ability to perceive direction is pretty weak, hence why it is chosen as a crossover point from main speakers to sub(s). It is a waste of time to "walk bass about" for that reason. It is also an acoustical nightmare to have bass "walking" all over the room.Remember, with the usual 80 Hz, it's only sub-bass that isn't in the mains. Lots of bass is in the mains and can 'walk about'.
Your argument on any possible negative room interactions in the surround bass range is the same that exists for any 2 ch system only somewhat exaggerated.At 80Hz, your ability to perceive direction is pretty weak, hence why it is chosen as a crossover point from main speakers to sub(s). It is a waste of time to "walk bass about" for that reason. It is also an acoustical nightmare to have bass "walking" all over the room.
It isn't about directionality. It is about having the bass being externalized ( not be 'in your head' like headphones) and for a sense of spaciousness and envelopment.At 80Hz, your ability to perceive direction is pretty weak, hence why it is chosen as a crossover point from main speakers to sub(s). It is a waste of time to "walk bass about" for that reason. It is also an acoustical nightmare to have bass "walking" all over the room.
