Not good for home audio
SirPaulGerman
I was going to buy this mint BGW 750D vintage amplifier, nice specs I guess
However I was able to find the professional review of the amp.
One line in the review give a pause;
"is not up to freak hi-fi requirements"
what do you guys think ?
see review
Without risking downloading a PDF, the general specs of the amp are fine when new. Perhaps you could quote some of the relevant passages.
No 1980s amp is mint in 2026 unless it has been restored. My biggest concern would be its aged components unless you are good at analyzing and repairing them. Has the owner restored it.? My 2nd concern would be the fan. Many pro amps were designed for environments where audible fan noise is not an issue, and even if it was noiseless when new, many are not 40 years later.
Of course, if you pay $60 at a yard sale vs $700 restored in a boutique (where the value would be nostalgic instead of objective) makes a difference.
The PDF is fine, dont worry, If I get the amp I am going to full restoration
Is this AR (Antiques Roadshow) or ASR? :)
I interpret both specs and measurements such that distortion and noise are inaudible. 113 dB SNR at 250W amounts to somewhere above 90 dB at 5W, to be compared with @amirm's measurements (if I'm not wrong).
According to the review the fan can be switched off for "normal" conditions, which may be the case for hifi home use, enough room for air flow provided though.
This doesn't look so good:
Would it be audible?
Pretty unlikely. As to fan noise, if it's not switchable, it should be pretty easy to make it so, or as I did once, attach a temperature switch to a heatsink, to come one only if the heatsink temperature exceeds 50 or 60 degrees, i.e. party mode.
S
