Nord's new Value-Line Hypex NCore MP series
, but still for me it’s a bit of of leap of faith as I have no opportunity to hear one before I spend a lot of money.
Remember that Nord has a 14 day money back guarantee, worst case you would lose some restocking fee and shipping back, no big deal to try one yourself.
Thank you very much for your replies.
From these and all I have read about the products, it appears they offer great value for money, but still for me it’s a bit of of leap of faith as I have no opportunity to hear one before I spend a lot of money.
From a value for money perspective, within my current setup would one of these be a better option than one of the big name offerings such as the Mission 778x or Audiolab 6000 for example, both of which are in a similar price band once you’ve added VAT.
Thanks very much
I've had Crown, Lab Gruppen, Denon and now Hypex amps. It's a rat's hair the difference and even more so if using for a surround system ( which I don't think you are ). Essentially any Hypex based amp will sound the same. Perhaps find one that supports money back within x days. Once you've heard one Hypex you've heard them all.
Thanks very much for your responses, it’s much appreciated.
I hadn’t considered the 14 day return option, that certainly helps.
In terms of what I’m looking for, I guess I’m just searching for that extra ‘something’ like we all are. I’m generally happy with what I’m getting from the Ultra/V3 Mono/Oberon 5 setup but wondered if one of these Nord Amps would give me more power/resolution/depth/soundstage etc.
But if there is a view tat I’m just moving sideways rather than up, maybe I need to think about it a bit more?
Assuming the Ultra and Oberon 5’s stayed, what would an amp upgrade look like - or is it all ‘in balance’ and doesn’t need fiddling with?
Power? Yes. Resolution/depth/soundstage no (whatever "resolution" and "depth" are).
I’m very confused now
Am just a casual amateur, but the general feeling here is that unless very badly designed with poor parts, all amplifiers sound very similar. So "upgrade" for more features, aesthetic appeal etc, but possibly better spending any "spare" $$$ on better speakers rather than on the electronics......
Hi, these threads meander off topic ... what are you confused about? It might be simple to clarify
Pretty much - YES!
Speakers are 10 to 30 times more important than the choice between a good and an exceptional amp (Purify amps are exceptional).
Just look at the Frequency Responce to get a feeling for the differences between things which includes mechanical parts and ELECTRONICS!
Pretty much - YES!
Hi Totti
Re Purifi amps, I am well aware that I really need to listen in my own environment with my electronics before making any purchasing decisions, but do you think it might be worth a trial of NAD 298 power amplifier? Currently ex-demo, unblemished with full packaging and warranty available in UK from well known retailer for £1,099. Other parts of the chain in my living room (excluding my headphones set up) are currently Fosi V3 amp (with 48v external power bric), Fosi P3 tube pre-amp (for tone controls and BT capabilities), an SMSL PL-100 CD player, a Wiim Pro Plus Streamer/DAC...all feeding into DALI Opticon 1 Mk 2 bookshelf speakers on DALI stands. Your thoughts any any others from forum members would be highly appreciated:) Thanks
Pretty much - YES!
Pretty much - YES!
And more important than all of that of which very few people acknowledge is the room. The room has more effect on your speakers than anything else.
Hi Totti
The NAD 298 is also an exceptional good amp!
But you can purchase these kind of purify amps also for half the price from Audiophonics.
The Room and the placement of the speakers in the room is so much more important!
thw
Hi Totti
I think, there won’t be any audible difference between the NAD 298 and this N Core amp, tested by Amir, highest range, for one third of the cost. Enough Power, nearly the same Bruno Putzeys technology, and I presume the same reliability:
thw
I moved house recently, in my old house my listening room was that classic shoebox rectangle - sound was fantastic
Now in my new house the listening room is square - sound quality has gone downhill so bad i thought the audio equipment was broken, i thought the removal men must have dropped it or something. I was ready to open up the equipment and do some trouble shooting. Room and room treatments are something to be seriously looked at
Had a similar experience. Not just room shape, but also floor material/construction (reinforced concrete vs. wooden planks on beams).
Just trying to say that in my latest experience the room makes a huge change.
I hung large blankets and wooly throws over all of the walls, the volume went down, now the walls are absorbing the sound waves rather than relecting them back at me, certainly sounded better
Hmm, I am predicting $2,999 audiophile blankets, made of tibetan yak wool, next... :)
