Nordost Blue Heaven AC Cord Review
Rate this power cord
  • 1. Waste of money (piggy bank panther)
    Votes: 327 94.8%
    Votes: 3 0.9%
    Votes: 5 1.4%
    Votes: 10 2.9%
My point was that Rolex (for example) are not making extraordinary claims about the technical performance of their watches. In other words, they’re up front about the fact that they’re selling luxury. The same can’t be said about most high priced audio cable makers who make extraordinary claims about the performance of their products.
Well, yes, I accept that's true.
But don't you think there's a kind of nod and a wink that is, at least some of the time, fairly well understood between the purveyor of snake oil and/or silly techno-bafflegab and its consumer?
True, the conclusion cites a preceding test, comprising listening sessions that were described by a different author, (and were widely criticised for what seemed arbitrary correlations). However my point was about how even correctly measured parameters percolate through the pores of an unverified info spreading system to be used in a wrong way by marketing. It was the sense of exposing field propagation speeds in the Nordost catalog for speaker cables, using that parameter alone to rank the cables, (and try to suggest that prices are justified).
Well, I can agree with that. But I'm also pretty sure that magazine had similar motives.
A well written paper comprising the 'speed of light 'argument is here, unfortunately it's in italian, and a pdf.
The experimental setup for the measurement session is however clearly explained.
Thank you, Bard:
Black,blue,white and gold all in one place?
That's nice only in an rainbow!
(I stop,taste is so personal we can make safe fun with it)
rolex-submariner-two-tone-stainless-steel-yellow-gold-black-dial-ceramic-bezel-ref-126613ln-484194.jpg
Why stop? There is nothing but to have fun with that product... :)
I don’t know (or really care) what goes on in the minds of those who buy audio snake oil. People are free to do whatever they want with their money. My contention is solely with manufacturers and dealers who make fraudulent claims.
This is a review and detailed measurements of the Nordost Blue Heaven AC Cord. It is on kind loan from a member and costs US $417 at this length (2m).
This is "third-tier" product in Nordost line so naturally, it is not going to scream expensive. That is a good thing as the cable itself is kept to less than crazy thickness. It is flexible but doesn't want to rotate which is a requirement for AC cord. Fortunately the connectors are easy to plug in and the weight was not excessive enough to yank your gear off the table/rack. I like the beefy plugs that make it easy to handle the cord. Here are the marketing claims:
I must say, I had not heard of "high-speed" as something good in AC cables. After all, high-speed means no filter or else, it would not be high-speed! We will test for its speed in the measurement section. I got a chuckle out of the claim that their claims are "proven." Naturally no such proof was provided.
While the plugs have UL/CE marks on them, the whole assembly has no mention of safety regulation either on the packaging or the marketing material. Only conclusion then is that the cable is not certified which is a sad thing when it comes to something that handles high current/high voltage and can cause safety risk.
Nordost Blue Heaven Measurements
Every time I go into one of these tests I think about how to expand our testing and come at the product from a different angle. While some of this testing may seem familiar, some are new. As usual, comparison is against a generic cable I had handy. In this case, I had a white AC cable that is marked as "I-SHENG" and comes with UL mark on the cabling. Company website says:
"Isheng Electronics is a world-class manufacturer of AC power cords. We offer a wide range of power cords including different NEMA AC power cords and different International power cord configurations. "
There is mention of speed of proven technologies; only that they are safe.
As usual, I perform my high-voltage tests by sensing the wavefrom using a B&K high-voltage differential problem with 100:1 attenuator. Here is my AC waveform using the I-SHENG generic AC cord:
We see that the tops of the AC waveform are deformed resulting in a lot of harmonic distortion and noise. Treating this as if the power company is an amplifier, its SINAD is 31 dB. Let's swap in the Nordost Blue Heaven and see if it makes a difference:
It doesn't make any difference. Everything bad that was there continues to be bad.
Some say my power is clean. I don't know how anyone could say the above is clean but let's use my B&K AC generator to create a highly distorted waveform, simulating what a dimmer would do:
Let's agree that is one bad AC waveform! Our SINAD has now sank to just 5.3 dB! Let's pump that into the Nordost Blue Heaven and see if it does anything to it:
Once again it doesn't.
While we are here and have an AC waveform that has nice sharp transitions, let's look at it in time domain with bandwidth of the analyzer expanded to 1 MHz. Here is the comparison:
There are actually two waveforms there: one in blue for Nordost and another in red for generic cable. As you see, every pixel has landed on the other demonstrating that there is no difference in any aspect of that AC waveform including its sharp rise and fall time.
So far we have measured the AC waveform. Contrary to what Nordost claims, your audio gear doesn't run on AC. That input waveform is converted to DC and filtered heavily before use. It then drives the electronics that makes audio signal. That is all we care about as that is what we hear, not the AC waveform. So let's test for that.
Topping A90 Power Cord Measurements
Let's use the Topping A90 preamplifier/headphone amp that is on my desk to test the difference starting with generic AC cord:
Once again we get the superlative performance we expect. Now let's switch cables to Nordost:
Once again no difference.
Let's finish with a proof point of why AC tweaks don't work. I used the chopped dimmer AC waveform and fed it to Topping A90 with the generic cord. Here is the output:
Yup, there is not a hair out of place! We have the same superb performance coming out of headphone amplifier even though we nearly destroyed the AC waveform! That chopped up waveform in blue when it, and what came out was the red.
Both our old and new tests prove once again that power cords make no difference (as long as they are thick enough to handle the currents you need). We expanded our tests into time domain and saw no improvement with the Nordost cable. If the cable can't change the AC signal, surely it means that the output of our audio gear remains the same and that was indeed the case. We then proved our conclusions by supplying our test audio product with highly distorted AC waveform and its performance didn't change.
You can buy an AC cord on Amazon for about $10. It won't look as fancy as the Nordost but you can sleep easy knowing that it is safety tested and costs 40 times less!
As an aside, the owner was sold on this cable by an audio salesman that made it sound like his gear would not be complete without it. He couldn't hear a difference so sent it to me for testing.
I can't recommend the Nordost Blue Heaven Power cord.
Gosh, you mean that copper wire has consistent electrical properties? Who would have thought it? It's like zip cord vs. miracle speaker wire. Shocking. <g>
But it was about speaker cables? ChatGPT also made it about power cables, but if you lookup the products, and look at the picture, they are speaker cables. I’m also not sure the essence of the article was captured very well.
On the other hand, if Bard made this of it, it’s probably also what the average Joe would make of it…and it clearly shows the motives of the magazine.
Gotta audition for a long period of time. Probably until it's too late to realize you were scammed.
As I'm being kept up all night by a purgative while awaiting for my every decade routine colonoscopy, it's nice to see I won't be the only one getting hosed. Obviously anyone buying the Blue Heaven will as well. Btw, I bet that ac cable probably has about as nice looking of a sheathing as the one being employed in my GI tract later today. You would think for $417 they could at least make it look like something better than hospital grade tubing.
Send us the video! Enquiring minds need proof!
Yup. And this pretty much confirms it:
There is also not enough demand for these to prompt Chinese manufacturers to invest in creating custom tooling and production lines to replicate them, as they do with replica watches and fashion.
It’s pretty comical that BOM for these is likely hovering around $30 and they are able to actually make sales at $50k+. I cannot think of another industry with those margins, outside of Pharmaceuticals of course.
How much do you really know of Pharmacueuticals profit margins?
Maybe they tested the same way as Amir when he was testing the other power cord as an interconnect wrapped around a transformer ;)
So much being squandered here with these products.
Grrr.
Such a waste of resources, wealth and attention.
Thanks for continuing to point this out. These products need to disappear. Sure maybe some added panache for looks but not at these prices and not with this utter lack of integrity.
It is about speaker cables, which in Italian is "cavi di potenza" so literally "power cables". Power cables are instead "cavi di alimentazione".
Italian AudioReview magazine has always kept a reasonable balance between "listening" and "measurements", being among the few magazines publishing non-trivial measurements of both speakers and electronics (plus, examining crossover diagrams of most measured speakers).
The issue is that they have gone a bit too far in dissecting a system's electrical performance attempting to correlate microscopic changes with allegedly perceived differences in sound reproduction. For speaker cables, we all know that higher propagation speed comes from lower specific capacitance and inductance, and it would make sense to choose a cable with low parasitic values. It is unlikely that it makes a difference once we are beyond the point of being a "good enough" cable. But same could be said for the last dB of SINAD on a DAC.
Two thoughts (about all I am good for on a Monday).
1) when I think of monofilament, I'm thinking more along the lines of...
2) Can I use a monofilament power cord for stereo? How about multichannel?
(OK, I'll stop... at least for now...)
As we say in Germany: Alles Lacksäufer.
This is great!
