digitalfrost
If amplifiers had clipping lights, it would be no problem. Then you'd know. The audiophilia nervosa comes from not knowing whether the power is enough. People tell all kinds of stories about transients, but if you look at the waveforms of modern music, there is very little dynamic range indeed.
Above 100W, amp prices start to climb fast. IMHO, if you need more than 200W/8ohms you have the wrong speakers. Given the logarithmic nature in speaker sensitivity, the money would be much better spent on speakers that are loud enough by themselves, instead of very powerful amplifiers.
Also, the most power would surely be required in the bass. I've designed a couple of speakers and subwoofers. Show me a woofer that can take even 100W in the bass region. Sure they exist, but these are already beefy speakers. And that usually means they already play rather loud at 1W.
Of course, everybodys impression of volume is different. I mostly listen at 78-86dBC, when I'm really pushing I might reach 100dB. More than enough for me. I also listen at close distance. I reach 10W into my speakers on occasion, most of the time I need 1W when listening 'loud'. So I can see how you'd end up at 100W if you sit farther away. But if you really are a volume junkie, there are speakers for that. Horns for example. Also, by using multiple subwoofers, you can easily gain headroom where it's most needed and you add (multiple) amplifier power.
Sure that's an expensive solution, but I'd prefer it. That said, I like amplifiers that have enough power so that you could run other amplifiers with them, given a 50hz sine wave input signal...
