Nord MP NC252 SE Amplifier Review
Rate this amplifier:
    Votes: 74 40.2%
    Votes: 45 24.5%
    Votes: 59 32.1%
    Votes: 6 3.3%
Apparently not. However, they do seem to take the criticism seriously, which is always a good thing.
I very much appreciate the audio manufacturers who (constructively) engage with ASR members.
I know this board can do a lot better, i've seen it used in a diy amp that gets an 96dB Sinad and both channels are exact the same. He did not mod the board, just put it in a custom case with connectors and a power switch. The owner, an electronic engineer tested his build with an APx555 like Amir has (from his job). But he took care about the routing of the cabling and tested the board before the build (and would have sent it back if it did not meet spec or had faults). Here clearly something went wrong, or a bad board (that nord should have tested and reject) or the cabling is routed back and causes extra noise.
SINAD 5W = 95.39dB. Both channels are almost same. And due to large effective heatsink (not only a cosmetic feature) the continuous power is high.
Something curious: Hypex specifies 2.5mOhm output impedance below 1kHz, your measurement shows 16 - is that the module itself or including all contacts and wiring?
Just made me appreciate my amps without input switches, only direct XLR inputs. Less mechanical points of failure.
Now curious to see Amir test an NCx252MP based amp to see how the new modules improved.
Even if that were true, it still wouldn't change the fact that anything NC252MP simply can't compete with an NCx500 amp. It's a silly comparison.
Also, have you watched the economy? 500 is a lot of money for most people, including audiophiles.
More like $400... in a hobby filled with equipment costing tens of thousands of dollars, I am not sure why you would get a good amplifier when you can get a great amplifier for the cost of a nice dinner or two.
You keep assuming everyone in the hobby is filthy rich. A profoundly false assumption.
Also, when we're staying scientific here, the audible difference between a 500 and 1000 moneys Hypex amp is close to absolute zero. So much for "good" versus "great".
The big service forums like these are doing the hobby in the first place is proving beyond reasonable doubt that great, even end-game sound doesn't cost tens of thousands of dollars.
Although I am staying quiet at the moment as far as the forum goes, I can assure all we are still investigating and talking with Amir directly for now (owner of the amplifier is also aware of our discussions).
The NC525 module from Hypex is fully integrated with amplifier and power supply. As such, there is less to go wrong with it. Yet, we have an amplifier here which seems to drop its performance by not an insignificant amount of 10 dB. Maybe it is just this sample in which case, I encourage the company to send me another to test. Until then, I can't recommend the Nord One MP NC525 amplifier.
Some manufacturers reported here on ASR that these Hypex all in one plate are the reason why they are unreliable.
I don't find this argument convincing. Amplifiers with an integrated PSU are simply more difficult to repair if they fail. Reliability is more related to the quality of design (components, engineering, heat dissipation, etc.)
2.5 milliohm is absolutely unrealistic, if you take into account any wire length. 20 cm of Cu wire pair of 1 mm2 cross section (40 cm total length) would have 8 milliohm resistance. Add contact resistance and you are there. All that race for milliohm output impedance is again a nonsense. Damping factor above 50 or so has no audible effect, other than audiophile fairy tales.
@Tone :
I made some comparisons between L and R channels on my NC252MP implementation a 5W/8ohm/1kHz. My results and conclusions: Right channel is slightly better than the left one regarding both distortion and level of mains induced spuriae. This may result from physical proximity of board components to the SMPS section.
At higher power, namely 40W/8ohm, the result seems to be consistently similar.
One channel is better (though not significantly) than the other one. If it is the left one or the right one may be a question of wiring inside the amp case.
Is this a standard layout used by nord for all ncore hypex stereo amps.
Ie. Nc122, nc252, nc502.
Would it make sense to order the budget case value line option instead.
There is no rca/xlr switch to be a potential problem.
It would be barebones as it gets.
And for those who cannot get their unit measured, it would provide peace of mind for the problems not being audible to the listener.
How about the channel imbalance tolerance issue. Is hypex aware of it. Have many been returned to them.
Gain balance is excellent, see the post above. Some distortion and noise imbalance is inevitable due to the all-in-one on-board concept. However the difference is unimportant.
Yet we didn't see as much variation as your tests (even though minor) and nowhere near as much as Amir measured in this review, compared to;
JSmith
@Tone :
Conceptually it would make some sense that proximity to psu section affects measurements slightly (or pcb signal routing).
In our amplifier builds
Right = CH1 (closer to psu)
Left = CH2
For this theory to apply pma, presumably you use the reverse?
In any case the channel differences pma measures on his build is insignificant with overall excellent results.
Nobody should question the reliability of these modules, or the sound quality. Implementation is the key.
Why our amplifier measured worse will be revealed when we know for sure, rather than speculating.
Reactions: pma
