"Golden sample" for the consumer; probably because it has not been 'tweaked' by the manufacturer!How can it be a golden sample if it didn’t come direct from Nord?
[aka a production unit.]
Or there is actually a fault other than what we would expect."Golden sample" for the consumer; probably because it has not been 'tweaked' by the manufacturer!
Exactly.Maybe puritee made a jokeconspiracy theorist always elude to "golden samples" if reasonably priced products perform very well in these kind of tests .
In reality the functioning units are so similar due to the way modern electronics are designed so it's no point picking one they perform the same or not at all ? Maybe a function test before it's out for a review ( in case of user sending something it's out manufacturers control ) .
The "golden samples " are in reality this kind off stuff when something is off and not as it should be![]()
www.audiosciencereview.com
Hardly comparable. A whole module generation and model up, double the price.I think the Apollon and others created such a high bar that you really have to compete at that level. The Apollon is a little more money, but with exponentially more power and chart leading specs.
Apollon NCx500ST Stereo Amplifier Review
This is a review and detailed measurements of the Apollon NCx500ST stereo class D amplifier based on Hypex NCOREx NCx500 modules. It was kindly drop shipped from the member and costs 1,090.00€ (US $1,168) with standard opamp. While the case is stamped aluminum, it is a heavily customized one...www.audiosciencereview.com
I think a majority of people putting together a system at a typical "audiophile" level would not quibble over a few hundred dollars.Hardly comparable. A whole module generation and model up, double the price.
Even if that were true, it still wouldn't change the fact that anything NC252MP simply can't compete with an NCx500 amp. It's a silly comparison.I think a majority of people putting together a system at a typical "audiophile" level would not quibble over a few hundred dollars.
Maybe the have the fins just because they look cooler?The overall layout is unhappy. And why do they use heatsinks with good thermal coefficient if they in fact do not use them for module cooling?? These assemblers without understanding of design principles are strange.
Terrible quality , they need to change the switch to something better, the ones built for audio works fine for decades ? Anyway a good thing that the amp works as it should nowCompany rep suggested to exercise the input selection switch as that has been known to cause problems like this. I am used to this being the case in older audio products, but not new. Still, this amp had been sitting here for a few months and as it happens, I had toggled one of the switches but not the other. Switching back and forth half a dozen times seems to have fixed the problem. Given this, I ran the rest of the tests and updated the review. I updated my recommendation. You may want to do the same with your vote.![]()
