Nord MP NC252 SE Amplifier Review
Rate this amplifier:
    Votes: 77 40.1%
    Votes: 46 24.0%
    Votes: 61 31.8%
    Votes: 8 4.2%
To answer that post's query: no, the grain structure of a cable's copper is not going to affect how "smooth" the signal's "ride" is and alter it in some way we cannot measure, regardless of the usual bad car analogy by someone who doesn't understand the topic.
And there is the science part.
Dealt with all this for years, I did once believe myself.
It's the 'single crystal' aspect that is the important part, seriously.
Well, if you believe hard enough... Tinkerbell effect
Is there any advantages of getting nc252 over nc502 if I don’t need as much power.
I will be using it in stereo. Possibly using a three way for lower intermodulation distortion.
Ie. Is there less distortion when listening at mid to low volume.
I don’t quite understand the sinad vs watts comparison graphs.
Hi Pritaudio
We have been conversing on pm and email.
The difference between the modules is the ability to drive larger more demanding speakers louder with the NC502MP and keep audio quality equivalent at lower volumes.
There are some (small) differences in THD+N, SNR, SINAD etc and I can't say whether these are audible or not to anybody under any circumstance ie actually relavent at such respectable figures.
You requested Nord V-L NC502MP over V-L NC252MP initially as a more universally capable amplifier if your requirements changed, without any compromise to sound quality, and I agreed it would be as such.
You can easily overthink these things..
Just fyi, new Nord One NCx252MP now in production with Nord PCSS (tm). SE version will have rerouted front switch signal cable as well.
Thanks again to Amir in his assistance to continued improvement.
thats great news thank you
For sake of further info.
This is a floating shield which works for both rca and xlr by equalising interference over entire cable length and width.
Further improvement would be grounded shield, mostly affecting rca (single ended) but will make virtually zero difference for xlr (balanced) except for impedance imbalance of preceeding preamp/interconnect.
This could be offered as an 'upgrade too far' in near future..
Speaker wires are twisted to reduce interference transmission due to switching frequency residual
general question to many, but is there a reason to have passive speaker bass/tweeter wires inside cabinet twisted? (getting my speaker DIY kit and was wondering, while im building it anyway..)
Not really. The cabinet provides ample distance to anything else.
It depends, when the coils are to close to the magnet there may be interaction, and the pressure in a cabinet can damage the crossover (but then the volume will have to be extreme. The crossover also dispensate heat, that can be a problem when the cabinet is very small. But those are all only a problem in extreme cases (+99% of the cases not).
The main reason why i like to keep the crossover out is that it's easely accessible to change or repair. It also makes my speakers more flexible to change to active. But both reasons can be a non issue for you.
Linn did exactly that with Isobarik many years ago, unless I'm very much mistaken.
Only for the active version, I think.
Linn made Isobarik as passive initially but then adapted to active, when they hoped the market had caught up.
Totally off topic but relevant.
I think they made the active to sell more of their amps (where they made their money).
