None of it matters anymore. None of it.
Why would you identify AI music at all. I rather worry about a few million AI agents that will flood the labour market for almost zero cost with all consequences.
For music, mostly because it's a bit of detective work to do it.:)
For certain styles I think it will soon become almost impossible to tell if it's AI created or not. Especially when it comes to generic types of music/sound, for example ambient elevator music.
That sort of music has always required some sort of cybernetic intervention. I broadcast a lot of "new-age" or "Space Music", late 1980s, early 1990s. Loads of those musics were one-man band creations, looped samples on synthesizers that merged back into themselves, coated in hazy reverb digitally created, a smooth miasma designed to put you to sleep. I think this use of sequencing really goes back to Terry Riley, though there might be even earlier examples in avant-garde electronic music that came before.
Did you read "Stranger in a Strange Land"?
Yes. Read and re-read and adored when I was 16 yo. Unreadable to me now.
One of the Martian concepts in the novel is that the physical body could "discorporate" while the mental and spiritual bodies continue to grow and function. Beethoven's like that, reaching a point where he could no longer play the piano in public as he became stone deaf, no longer alive in the performing arts where he once excelled. It is as if after op. 100, all his compositions are effectively posthumous.
Yes, and there's the famous story that he had to be turned around to see the audience cheering at then end of the first performance of the mighty Ninth.
Every performance of a Colon Nancarrow work would be/is a definitive performance of that work. There are the piano rolls and there are the pianos set up for those rolls and there are no other options. Just press "play".
literally 'program music'
I tried asking Microsoft Copilot (ChatGPT) what it thinks of this thread. Somehow it knew it was about AI even though it claims it can't read the contents of the thread.
humanity is doomed
I tried holding its feet to the fire, but got gaslit instead?
I guess i should just host a local version of ASR-themed moltbook and not even bother signing in here :P
humanity is doomed
Ah, absolutely classic.
As you demonstrate, the idea that LLM-based chatbots can ‘claim’ with veracity is of course erroneous. Generative text descriptions of the chatbot’s function in any specific instance is probabilistic and not tied to actual chatbot function in that (or any given) instance.
Naturally if the text string reads that the chatbot ‘can’t read’ the accuracy of that as an actual description is stochastic.I reckon you can (and it looks like you maybe did, I haven’t read them all) prompt it to say most anything.
I ended up having a stranger conversation as I went along, based off trying to parse what you said, before you edited it (as I pasted it to the chatbot):
but be warned, he kind of insults you :D
Then we talked some more (wish I didn't have to post it in so many links, but that's all it allows):
i wasn't that serious (and wasn't really angry) about the copyright stuff, I just wanted to push the conversation somewhere, which next went to questions about moltbook's apparent religion, but this is taking things even more off-topic for this thread/forum:
.. so i'll stop there
Haha, and I did read them all this time (vanity will do that).
And as you probably guessed I thought my first version read too much like tech-splaining and didn’t convey my reaction to your post so well. Copilot did rather a lot of bullshitting there before eventually allowing that ASR content could very well be in the relevant training corpus?*
It doesn’t really get what stochastic means though (if you’re on an Apple device you can use the look up, otherwise I think it’s concise Oxford rather than Miriam-Webster in my region).
Yep. In other words I don’t really mean it in the sense of ‘random-ish’. Oh and stochastic doesn’t mean probabilistic at all, that’s a bit hopeless. I expect Copilot is tweaked to lean a bit toward avuncular in preference to technical. I would find that very frustrating.
*Not the words you just typed on ASR, but wherever the training corpus ended with. Meanwhile my phone really wants to say ‘tracing’ there ffs. I’ll correct it for the third time now …o_O
humanity is doomed
Is it AI Marvin?:)
I find everything about AI quite boring, especially discussions of its outputs.
Which may be exactly what AI wants (should I be reading Moltbook?)
Funny you should mention that!
As a matter of fact, I do have a Wham! LP.
The photo above is from our old house in MA ("House 3.2")
It was given pride of place in the new house ("House 4.0") in NH early on in the transitional process...
You can see it there above the two EICO components and below the two wind-up Martin Luthers.
:cool:
