Noisy LP Temporarily Noise Free - Why?
Tamarack
Hi ASR,
This is my first post, though I have often enjoyed and benefitted from the discussions presented here. This seems to me to be a great place to post this topic. I will try to be brief!
I am at a total loss to explain what I observed last night during routine vinyl recording. I Spin Clean'd a NM used copy of Bolt Thrower's In Battle There Is No Law (BOBV306LP) I had recently acquired. Whenever I encounter a perfect looking record that is inexplicably noisy, I would always love to know why it is noisy (e.g. sample, batch, storage or treatment problems) but usually I just shrug my shoulders and accept it as permanent. The A Side of this record was very noisy (periodic and temporally broad, gradually improving as it played). After recording the A Side, I flipped it to the B Side, verified that its lead-in grooves indeed exhibited similar noise, and took an hour's break for unrelated reasons. You can see the noisy waveform and spectrum from this preliminary test of the B-Side lead-in grooves (attached image A).
Noisy Side B lead-in grooves during preliminary test (A) and following an hour's break with no purposeful intervention (B). The two recordings were truncated for visual clarity. Noise in (A) is almost entirely limited to the right channel.
When I came back and restarted my recording of the B Side, I was shocked that the lead-in grooves were now well within my normal NM record experience (attached image B). I recorded the entire B Side with negligible noise throughout. All subsequent playback attempts of A or B Side lead-ins have demonstrated similar noise level and pattern to (A). I am strongly compelled to solve this problem. What is the cause of this noise? Since this noise is not permanently "baked in" to the record, what can explain its disappearance after a casual pause? Perhaps most practically, how can I mitigate or eliminate this noise reliably? How many of my records have I unfairly banished to the bad sample dog house?
I'd really appreciate any insight anyone may have!
I'm guessing static electricity that bled off when you left the table alone for a while.
I have to admit this is an issue I never had a very effective solution for. I never found the Zerostat gun helpful, for example.
The one-channel-only pattern is the clue — true groove wear or static discharge would usually affect both channels. Noise that gradually improves during play, disappears after a break, then comes back sounds more like contamination or charge on one side of the groove plus static re-accumulating — especially right after a Spin Clean, since friction from cleaning and dry air both build charge. Practical checks: clean the stylus before assuming the record is bad (a dirty cantilever side gives exactly this), brush the side with a carbon-fibre brush right before play, and keep the room around 40–50% humidity. The Zerostat only helps if you follow the pull-away motion correctly and use it right before dropping the needle; otherwise the charge returns within minutes.
Thanks for the replies! I intentionally didn't mention the s-word, but it was something I was wondering about. I don't know exactly where I stand on the issue of static on records, because I don't believe it's been much of a problem for me. I live in a fairly humid environment, and I've never been able to concretely attribute noise problems to static before, or seen static endure, even with a new record when the glossy paper inner has an anvil grip on the disc.
I recorded a different record NM last night, Bolt Thrower's ...For Victory, from the same source as the first record, and it recorded flawlessly. When it was done I tried In Battle once again: noisy. Tried it also on my second setup in the basement: noisy. So it seems this noise problem follows that disc around. If I hadn't witnessed the one noise-free playback I got (sandwiched between exclusively noisy ones), I wouldn't have believed noise-free playback was possible. Would a Zerostat help here? I'm skeptical, but I bet most people are until they've been shown it works, and evidently lots of folks have.
Could you elaborate on this? I have never paid much attention to cantilevers. My main cartridge is an AT-VM540ML with a tapered aluminum pipe; are cantilevers prone to accumulation that can lead to noise in only one channel? Would a stylus with a boron cantilever (i.e. AT-VMN45xML) behave differently from an electrostatic point of view?
