And that's exactly where it gets not just warm, but really hot.
Of course, the DSC-88 doesn't comply with the latest SPDIF standards, and that's exactly what it's not supposed to do. This is only about stereo (2-channel, not 2.1) standard SPDIF.
The standard was only expanded, not changed, because that would be fatal for any compatibility.
Tens of thousands or millions of devices that work with this standard in the professional audio sector with device generations well over 30 years apart with virtually no problem, but the really big TV manufacturers can't manage this data output?
I understand your point about backward compatibility, but if I were to consider using optical SPDIF, I'd at least want it to do 5.1. (That has been a long standing capability of SPDIF IIRC). From my point of view (and maybe the TV manufacturers) it would be better still if it could bitstream Atmos (obviously, in an ideal world, adding this shouldn't break anything else).
if eARC works for you and your dac/avr/whatever+tv aren't having dropouts there's no reason to make any changes.
if you're having dropouts, then try a different connection method.
Yes - very sensible suggestion. I may be hearing increased noise/distortion rather than dropouts. Unfortunately I've changed many things at once in my setup (AVR change from TI to ESS DACs, speakers, calibration, etc). So at the moment it is a bit hard to pin down. I was initially suspecting the upmixing or loudness compensation processing as these seem to also effect the audibility of the noise. Anyway - I'm asking the questions in general for anyone who has an AVR with ESS chips and an LG TV.
