Noisy digital audio on LG TVs
My LG C2 was having audio hiccup’s using the optical out. I originally thought it might be my Apple TV box until I found this thread.
I switched out my topping e50 for a smsl su1 and that has fixed the problem.
Hey everyone, just wanted to share my experience with this issue, as I currently found a simple and supposedly bit perfect way to solve it.
My LG C4 was showing this exact problem (small intermittent audio dropouts) when using the optical out to send my apple tv's signal to a schiit modius e dac (ess chip). Having the tv's optical out first go through a fiio br13, and then sending the fiio's coaxial out to the dac solved the issue 100%.
Still not sure if it was excessive jitter or clock issues, either way my fiio br13 managed to "clean" up the digital signal before sending it to the dac for analog conversion (when hooked up this way the signal supposedly never touches the fiio's own dac, which might even be transparent enough anyway, haven't tested it). It also added a respectable bluetooth receiver to my system, so all in all I think it's a better solution than using HDMI extractors (which may or may not mess with the video signal going into the tv) or messing with the tv's arc output (which might output the same poor digital signal).
I have a couple of years old LG C3, and it also has this sound dropout issue from time to time when using the optical connector. I was deeply disappointed when I bought this TV, whereas on my other older Sony TV, the sound is perfect when using the optical connector.I then bought an Ezzo digital converter from Amazon, which has an HDMI pass-through cable and an optical output. It has completely solved the problem with my LG C3 TV.
My LG TV has optical out but it seems to play too loud compared to my Apple TV and I think I heard clipping, so I stopped using it completely.
Confirming that introducing an SMSL SU-1 DAC has completely solved the issue for me on my LG CX TV.
LG TV Optical Output -> SMSL SU-1 Optical Input -> Line Outputs from SMSL SU-1 -> Line Inputs on Triangle Borea BR02 Connect speakers.
