I had a strange problem where noise was getting into my preamp when a particular device (raspberry pi/DAC) was plugged into the preamp (via RCA interconnects). The noise was affecting the phono input channel while lisening to records with the Pi still plugged into the unused input. The device runs from an ungrounded power supply, so it should not have been a ground loop. I posted here https://www.audiosciencereview.com/...usb-dac-noise-affecting-phono-playback.10673/ about it but no replies as yet. I found the noise was reduced when I grabbed the shielded cable with my hand. I tried multiple different RCA cables. Strangely one of the quietest ones was the cheapest one. I took a good quality cable and rolled it into a coil (about 4" diameter and maybe 4 turns). This reduced the noise a LOT.
Hence my more general question here. Theory I have read, is that coiling a shielded cable does not raise the inductance of the inner conductor, but it does raise the inductance of the shield. Could it be the noise is some sort of common mode noise - hence the improvement when coiled? I wonder if a ferrite clamped on the cable might help even more?
