Noise connecting avr preouts to active studio monitors
In that case my suspicion would turn to the TV itself being the source of the noise. Is the noise present if you have the AVR and speakers on and connected, but the TV disconnected from the AVR? If the noise is still there with the TV disconnected, then I can only surmise the AVR itself is the source of the noise.
Yes if tv disconnected noise still there, even if avr is off. But the noise gets way louder when tv or computer is on and playing sound.
Wonder if its common to get such noise connecting avr preouts unbalanced to active speakers without ground loops. If no myb my avr is the cause
Wonder if its common to get such noise connecting avr preouts unbalanced to active speakers without ground loops. If no myb my avr is the source
I'm quite certain the AVR is the source at this point. It just gets amplified when content is actually playing. Even if the AVR is "off" (actually in some sort of standby mode), there is still circuitry running and therefore it could still be generating the noise. If you unplug the AVR from the wall and the noise is gone, this would confirm it. Either that, or something else in your house is putting some seriously gnarly noise into your power lines that's getting into your equipment.
You don't have any heavy equipment on the same circuit do you? Treadmill, air conditioner, air compressor? Or perhaps something putting out some serious RF interference, like a wifi router in the immediate vicinity or a nearby TV/radio broadcast tower?
The latter part of your post is what I was just wondering. Never had a component produce those noises, tho.....those do remind me of machinery/motors tho
No dont have any heavy equipment on the circuit and just tested disconnecting from outlets everything in the house except avr and speaker, same problem. Also tried different outlet and power strip. Also connected new hdmi cable to a different source-my laptop which same behavior, amplifies the noise alot. Also when the avr is on, even with nothing at all connected to it theres a very faint barely audible hum which is only really noticeble within a few feet of it in a dead silent room. Dont know if thats normal to have tiny bit of noise come out of the avr itself or it shouldnt be audible at all in a dead silent room. And another test i have another custom made cable dual xlr to trs. Connected it to speaker and the other side to the headphones output on the avr. Substantial amount of noise even with the avr off and nothing else connected but speaker. The noise is a bit different than connected to the rca preouts:
And Connecting same speaker and cable to computer or phones aux jack, no noise. Connecting headphones to the headphone output on the avr no noise.
From what i read online ai is saying "Your Yamaha RX-V6A is not faulty. This is a classic ground loop and impedance mismatch issue caused by interfacing the AVR's unbalanced RCA pre-outs (consumer-level, single-ended) with the BM6A's balanced XLR inputs (professional-level)."
And its saying to buy a transformer isolator box to turn it into a balanced signal, which im sure would most likely solve the issue, but not sure if the avr itself is faulty and that would just be a bandaid, and instead i should replace the avr
Thnx
It probably isn't this (and easy to rule it out) but to me that sounds like a laptop's fan noise (or possibly power supply whine), picked up by its internal microphone and played through the speakers.
If there is a PC and/or laptop connected to the system, make sure its mic is muted.
No thats not it. As explained it happens in few different configs, even when nothing connected but avr and speaker. nothing to do with a laptop. But sending sound via hdmi into the avr from tv or computer amplifies the noise. Its either the avr is faulty or this is normal expected behavior connecting an avr to active speaker without a ground loop switch via unbalanced cable, Not sure
Strange. Plug only the RCA to XLR cable into the active speakers. Short the RCA center pin to the shield. Is all well?
@Scopus
