Noise connecting avr preouts to active studio monitors
Scopus
I have a problem, just bought a new yamaha v6a avr that wanted to connect bm6a speakers as front lr via the preouts. When I connect my BM6A active monitors via XLR to RCA cable to the receivers front preouts I get a lot of electrical noise coming out of both the speakers. Both speakers are not faulty, If i connect the bm6a for example to my babyface pro on my computer via xlr to xlr i get no noise. But unbalanced to the avr i get a lot of noise. I have two of these xlr to rca cables both same issue on both speakers. Speaker connected to the avr, Even with the avr off im getting a little noise. When i turn it on same amount of noise until it turns on my tv which is connected via arc and my pc. Than when i see my pc on the tv screen the noise goes up much louder.
Also changing the volume of the avr doesnt change the volume of the noise. The noise only gets really loud when the tv with computer turned on. I did another test now connecting 2 different active speakers. 1 was active avantone mix cube to it with the same cable. If the ground lift switch active theres no noise also with tv and computer playing no noise, ground switch off get some noise. test connecting another speaker neumann kh310a same cable while tv/computer on. If the ground switch on back of the kh310a is set to "connect" i get no noise. So It seems with other active speakers like the mixcube or kh 310a i am able to have no noise as long as ground loop switch is in certain position. But with the bm6a there is no way to get no electrical noise and there is no ground switch on it. Also everything is connected to the same power strip. Is the avr faulty?
What is most likely cause and how to fix?
Connect your TV to the AVR via optical SPDIF if possible. Same for your PC, otherwise connect your PC directly to the TV bypassing the AVR. Also, what RCA to XLR cables are you using? Many of them are wired incorrectly.
Rather use arc as wanted to be able to control avr with tv remote. Dont think tv or computer are the cause as speaker still has alittle noise even when nothing connected except the speaker and avr. But seems audio coming through tv sound or the computer add a lot more noise. They are custom made mogami xlr to rca cables by proaudio la.
Thanks
You have speakers powered on when making connections?
If your AVR and active speakers are connected to different wall outlets, try connecting them all to the same power strip.
The noise is probably caused by an earth loop. The aim of the above is to create the smallest possible earth loop, which will hopefully reduce the amount of noise picked up.
The noise is probably cause by an earth loop. The aim of the above is to create the smallest possible earth loop, which will hopefully reduce the amount of noise picked up.
All is already connected to the same power strip
How are your rca to xlrs wired?
A quick look on the Pro Audio LA website says the following...
"By default, these cables are wired in the industry standard way, with the Neutral merged with Ground on the unbalanced side. If needed, we can also float the Ground or Neutral—just contact us before placing your order."
So, if you are confident with a soldering iron, you could try disconnecting the cable shield at the RCA end.
Can you characterize the noise? Is it more of a "hiss" or a "hum"? Is the little bit of noise you get with no source connected different in character than the noise you get once the PC is in play?
You could always achieve a ground lift by using in-line ground lifters, such as these, if lifting the ground alleviates the noise issue.
Its like electrical noise static, yh might be best getting a ground lifter, thanks
I didnt request from them to wire it certain way so guess they did the industry standard way. I have no knowledge of wires or soldering. If i buy new rca to xlr cable from a music store here will be good or liekly same issue? Or need something like a transformer isolator box?
Thanks
Thanks
I'd just try the different wiring possible and see if it makes a difference. I have rca to xlrs that don't have unusual noise....but I wired them as suggested for the specific purpose by Neutrik....
Its not just low frequency 60hz, and its not a high pitched hiss. Its like broadband electrical noise
That's a very odd noise! No experience with something like that myself....
Just buying a random cable is not likely to help, unless you make sure it's not wired the same way as the cable you already have.
The other issue is that the RCA output on the AVR likely can only put out somewhere around 2Vrms, whereas the balanced XLR inputs on your monitors are expecting 4Vrms. This results in you having to turn the monitors up, which also results in any noise in the circuit being louder.
That noise is unusual, not normal hiss or ground loop hum. I would guess the source is your PC, as you can get unusual noise transmitted from PCs (which have all sorts of internal components putting out noise that gets picked up by the audio circuit). If you can connect your PC to the AVR via optical SPDIF, that would likely help. If your PC doesn't have an optical SPDIF connection, there are USB to TOSLINK adapters widely available for cheap.
But get the same noise also from tv sound not just the pc. And even if tv and pc not connected and the avr is off there will be noise just much less than if tv or pc are on.
Dunno either the avr is faulty or its the unbalanced cable/connection and because the speaker doesnt have a ground loop switch
Hmm. Do you have anything else connected to the TV besides the PC? Like a cable box, or direct cable connection? Antenna?
