Noire Audio Player Win64
Jul23
Noire V1.06 Beta version audio player.
build 1.0.3 Tauri Rust Vue3
Who i am : iam jul23 ( 48 years old, french , actually live in Tel-Aviv, architectural designer) come from foobar2000 and made theme La Noire for F2K.
i wanted to create my own player and found what i think as a good platform with Vbcode and rust. full css , C++ and a lot of crates . and of course wGPU for special effects and acceleration.
link : https://github.com/julgilad-alt/LaNoire-
take Version V1.06
Features :
- ASIO ans Wasapi shared , exclusive .
- Formats : DSD , DSF , ISO , SACD , FLAC , wav , wavpack, ogg, aiff, and mp3 .
- Upsampling DSD up to 512. WGPU nvidia ans AMD compatible.
- Analyser : Sin , multitone , white noise and THD.
- Spectrum goniometer and lufs visualizations RT.
- SMB nas library incorporation .
Frontend :
- Library with filters , and editable metadata .
- Artists view with overview and doscigraphy with discogs and Lastfm.
- Scroobling LASTFM .
- Playlist creation, import export , drop N drag.
- Hardware: audio chain path , pc specs RT ( CPU , ram , GPU ).
- History Stats viewer.
- Radio player, full covers , playlist creation and add URL....
- export debug logs.
Screenshots :
Bit-perfect BPT test:
DeltaWave v2.0.25, 2026-09-22T11:53:36.4169510+03:00
Reference: source.wav[L] 240000 samples 48000Hz 24bits, stereo, MD5=00
Comparison: capture.wav[L] 240000 samples 48000Hz 24bits, stereo, MD5=00
Settings:
Gain:True, Remove DC:False
Non-linear Gain EQ:False Non-linear Phase EQ: False
EQ FFT Size:65536, EQ Frequency Cut: 0Hz - 0Hz, EQ Threshold: -500dB
Correct Non-linearity: False
Correct Drift:True, Precision:30, Subsample Align:True
Non-Linear drift Correction:False
Upsample:False, Window:Kaiser
Spectrum Window:Kaiser, Spectrum Size:32768
Spectrogram Window:Hann, Spectrogram Size:4096, Spectrogram Steps:2048
Filter Type:IIR, window:Kaiser, taps:262144, minimum phase=False
Dither:False bits=0
Trim Silence:True
Enable Simple Waveform Measurement: True
Correct for MP DC Filter = False, DC Filter frequency=0.5 Hz
Discarding Reference: Start=0s, End=0s
Discarding Comparison: Start=0s, End=0s
Initial peak values Reference: -6dB Comparison: -6dB
Initial RMS values Reference: -9.01dB Comparison: -9.143dB
Null Depth=-30.827dB
X-Correlation offset: 0 samples
Trimmed 0 samples ( 0.00ms) front, 0 samples ( 0.00ms end)
Final peak values Reference: -6dB Comparison: -6dB
Final RMS values Reference: -9.01dB Comparison: -9.01dB
GS: 0 ms, 0 dB (L), -400.0 dBFS (L), [-400.0dBFSA (L)]
Gain= 0dB (1x) DC=0 Phase offset=0ms (0 samples)
Difference (rms) = -400dB [-400dBA]
Correlated Null Depth=300dB [300dBA]
Clock drift: 0 ppm
Files are a bit-perfect match at 16 bits
Files are a bit-perfect match at 24 bits
---- Phase difference (full bandwidth): 5.74283348751103E-10°
0-10kHz: 0.00°
0-20kHz: 0.00°
0-24kHz: 0.00°
Timing error (rms jitter): 0sec
PK Metric (step=400ms, overlap=50%):
RMS=-∞dBFS
Median=-∞
Max=-∞
99%: -∞
75%: -∞
50%: -∞
25%: -∞
1%: -∞
gn=1, dc=0, dr=0, of=0
---Measurements (for a simple sine-wave only)---
RMS of the difference of spectra: NaNdB
DF Metric (step=400ms, overlap=0%):
Median=-300dB
Max=-300dB Min=-300dB
1% > -300.0dB
10% > -300.0dB
25% > -300.0dB
50% > -300.0dB
75% > -200.0dB
90% > 0.0dB
99% > 0.0dB
Comparison DR = 322.12dB
Comparison THD+N = -149.15dB
Comparison THD = 0dB
DONE!
Signature: bef7b9cbdd43b3e33cbb1218aeb69d42
it's a beta Version . Still a lot to improve... special things to Kippat1247 from Audiophile Style for his precious help as testers and others also.
All return for me will be great to improve bugs , wishlists , bugs and dislikes.
thanks , merci beaucoup.
Pretty, but I need gapless, replaygain and DLNA playback.
Post again when you have these.
(sorry if I missed any in the features list)
Came here to say that the name could be considered as disputable for some french speaking people but since you are french, I guess that you know what you are doing.
it's the same name as the theme i made for foobar2000. i did not change it. not important . no connotation at all.... ;) a major sombre color , darken color .
DLNA i have to work for it . gapless is almost finish , some testing to do yet... and the replaygain also.
thanks a lot Redacted and Boxem for your time and yours good advices.
a good weeks of work minimum and testing. Merci thanks U.
"Le Noir" could be a name for a major dark color, could translate into "Absolute Black", "La Noire" can't mean anything else than "The black female". For the billions rightfully not aware of French subtleties, "Noire" like used by DCA and others is also ok because i has no other meaning than a color when used alone.
i think you are right . i change to "Noire". definitly better. no more meaning ... thanks boXem :)
The name does not fly TBH, but who cares?
I mean, WTF were they thinking with Foobar2000, or VLC with traffic cones denoting slow roads if you live in Broken Britain?
'DarkAngel' say, would at least make the mascara on a goth drip a little.
To be clear, I would need DLNA to be able to scan for servers on the LAN, and allow me to select one, and in some kind of tree view, let me view the available virtual folders and playlists to make a selection, or do search. A bit like the old and usupported plugin available on FB2K 32-only. The FB2K have lost the plot on DLNA....
