pollock0424
- Joined
- Jun 30, 2022
- Messages
- 279
- Likes
- 134
Can you recommend an alternative maybe? (not to see the needle swinging but to actually measure)Not very likely, nor recommendable.
As this is an all passive device and measures current it must have a series resistance drastically reducing the DF so you can only use it with test signals and not keep it in the signal path just to see needles swinging.
Also the range in which it can measure is not that interesting... max.3 A which is hitting the max at 12V in 4ohm = 36W.
As we know, LED meters in the Hifi equipments do noise pollute.
Hypex actually use LEDs in their HPR12 Voltage regulator to build supremely low noise and distortion Amplifiers: https://www.diyclassd.com/products/diy-components/accessories/hpr12As we know, LED meters in the Hifi equipments do noise pollute. Best is able to switch them off.
Where do these old chestnuts start?It's safe to say that LEDs polluting audio is an audiophile myth.
I have no doubt a marginal design will introduce noise. Blaming the LEDs is like blaming the dog, though.I don't mind loosing a bit of SINAD for visual indulgence and I like to listen with my eyes open in a dimly lit environment. I think that audio experience and auditory cues can be reinforced with some subtle visual cues. Anyhooo....
I tried this and it is a total waste of time and money and stay from it. It was introducing audible humming/buzzing.
Douk Audio VU56 PRO MIC & Analog Sound Level Meter, LED Music Spectrum Visualizer, Audio Splitter with Remote Control https://a.co/d/7jVOmYd
I design LEDs into low noise circuitry all the time. It's not that hard.LED's generate shot noise and thermal noise. It's not an outlandish claim to make.
In the old days some audio equipment with colorful LED bar indicators had a defeat switch to turn them off. This was not just for the visual irritation they might cause.
There are more than a few books written on this topic.
Yes, they make Johnson noise and shot noise. None of that is the buzzing and humming the audiophiles complain about. I have to suspect cheap noisy switchers to supply the LEDs.No, it's not hard. So, you should well know things with PN junctions can certainly generate noise.
And, in devices like I think we're referring to here, had multiple LED's with most of them in a transitioning state all the time. (A colorful light show, to be sure.)
Somebody who's been around awhile might have memories of equipment like that. It could be XTRProf is one of those folks.
