Wondering if somebody can explain what's going on, after experimenting a bit.
If I remove all inputs from my amplifier and set it to SE, I can amplify a small hiss using it's internal pot, get it a bit louder, hear it about a meter.
Repeat with balanced selected, essentially nothing, if i squeeze my ear to the tweeter i can hear a very slight something.
Introduce to the mix, the NS-05P passive preamp with switchable RCA/XLR in/out, and a 20k alps 09 pot - note it's passive and no mains wire.
With the amp at full gain/it's pot wide open, the NS-05P connected via RCA to the amp (but nothing connected to the RCA/XLR inputs):
- the input set to RCA or XLR: I can amplify the small hiss using the ns-05p's pot/volume, get it a little bit louder than just bare amp.
However, with the amp at full gain/it's pot wide open, the NS-05P connected via XLR to the amp (but nothing connected to the RCA/XLR inputs):
- the NS-05P input set to RCA: I can amplify the hiss to a greater extent using the ns-05p's pot/volume, it's also lower in frequency. Hear it about 2m+ away.
- the NS-05P input set to XLR: nothing at any level.
Second point:
Additionally, under all scenarios there's a slight static noise as I twist the volume on the NS-05P. If I touch the NS-05P with my thumb or other hand whilst I spin the volume, no static noises introduced. Is this just my own electrical signal/static being ungrounded and amplified vs grounded?
Third point:
If I connect my DAC via RCA to the NS-05P and play something at -80db, such that when both pots are wide open I can faintly hear the music, retaining the RCA connection flow to amp, I can hear me "changing" the tone of the hiss between 9-3 o'clock, is this the varying ohm's of the pot changing it's tone?
So I guess the specific questions are:
- what is the hiss when RCA is in the signal path and not connected to anything.
- why does the 20k pot on the NS-05P appear to amplify it a little bit (maybe it does't, arguable)
- why does changing to RCA in and XLR out at the NC-05P out amplify it much further and make it a lower tone? (double signal via xlr?)
- why does removing any RCA sockets from the signal path completely wipe it? (this is perhaps a stupid question, but I'll ask it anyway, in case it indicates that there's no bleed through between signal paths on the NC-05P or amp for example).
Second point:
Third point:
