Ramon Cota
that lavoce is a winner !Below is a low level ~80 dB THD measurement from REW for a LaVoce SAF184.03 18" driver. It stays well below 1% from 20 Hz to 800 Hz.
but i have a severe lavoce loser as well
red line , mostly
between 40 and 180 hz
narrow peak of 2,7 % thd at 70 hz for scan speak and much broader peak of 4 % for much much larger pro woofer.
actually b&c loses with SS anywhere between 40 and 180 hz at 90 db
do you see it now ?
That site doesn't have a lot of serious pro drivers on it. If you look at the Faital 12HP1060-8 it is pretty good high and low. I believe Faital has more higher end pro drivers in their line up as well. There are no Eminence of LaVoce drivers on the site which are the most popular "Pro" drivers for Hi-Fi use and from what I have seen have no problems with distortion high or low frequency or SPL.red line , mostly
do you see it now ?
As has been mentioned if you want to use a "Pro Driver" for Hi-Fi uses you need to evaluate each driver individually as there is a large variation between drivers. The WXF15.800 looks to be designed for efficiency i.e. 98 dB at the expense of extension and some distortion. For some application this could be a winner, for Hi-Fi use there are better choices.that lavoce is a winner !
If the graph is to be believed, the B&C crosses the 3% threshold at around 70 Hz. The Scan Speak is just barely below that. What stands out most to me is that the professional driver still delivers volume and pressure where the hi-fi driver has long since faded out.actually b&c loses with SS anywhere between 40 and 180 hz at 90 db
do you see it now ?
the conslusion was that pro woofers distorted more at lower levels untill they reached 95+ db and only then started to distort less compared to hi-fi speakers
Also, I would add that there's often quite a lot of difference between the models of drivers made by each manufacturer, and therefore sweeping generalisations about brands often don't accurately correlate to a specific models performance.
I highly recommend looking into diy multiple entry horns like the Scott Hinson MEH* for home dj'ing/studio stuff, great sounding speakers with enough headroom and surprisingly low reaching bass. Everyone has asked if they can listen to the speakers without subs, which were muted all the time. I think these MEH/Synergy horn type of speakers are approaching the "perfect" marriage between PA, studio monitors and HiFi speakers.I think, in summary, I need to create a more even response with a wider and taller "sweetspot" higher up the frequency response
A pair of DIY MEHs are definitely on my todo list! Point sources with very well controlled directivity that can be built at quite a low cost, and you get the fun of doing it yourself, what's not to like?!I highly recommend looking into diy multiple entry horns like the Scott Hinson MEH* for home dj'ing/studio stuff, great sounding speakers with enough headroom and surprisingly low reaching bass. Everyone has asked if they can listen to the speakers without subs, which were muted all the time. I think these MEH/Synergy horn type of speakers are approaching the "perfect" marriage between PA, studio monitors and HiFi speakers.
I'm not saying they are perfect but they are pretty damn good speakers and on par with significantly more expensive midfield studio monitors.
*or JW Sound Solana, and if size isn't an issue, something like @gnarly showed or the JMOD MEH. https://www.jwsound.live/designs/jmod
Jesus. I hope you don't have neighbors.Using club speakers in my living room. Got several pairs of Tannoy V12s as I love big coaxials.
Getting plenty of volume using a wee Topping Mini 300 here presently, but have bigger Crown Macro-Techs if more Watts needed...
There's no replacement for displacement when it comes to "slam", I reckon!
Edit : I also love the fact that big passive club type speakers are actually super "eco" when used at home. Their high sensitivity means they need minimal Watts, even to go loud.
I can easily get my windows rattling with the wee Topping!
Honest question. Let's say a speaker is designed to play at 100+dB all day long. The voice coil and associated components would be engineered to dispose the heat and account for thermal expansion. The suspension systems would be similarly quite stiff and robust. What happens if you take that speaker and play it at 60+dB in a domestic setting? @Duke?
Nothing out of the ordinary. As usual – 2.5" tweeter, 4" MF, 3" midbass in 40 liters, four 4" subwoofers (two of which are inaudible (well, almost (I was working near the rear subwoofer right now, it's sometimes noticeable))). The voice coil diameters are listed. It's nighttime here now, around 60 dB.What happens if you take that speaker and play it at 60+dB
Lol. Some of my best clubbing memories, (plus lack thereof), were at a small place in Edinburgh called "The Venue".
I do. But thankfully they live in Holland most of the year!Jesus. I hope you don't have neighbors.
Two Scots.sharing tales of our adventures to weird and strange after parties whilst sharing joints and getting coffee from the local cafe nr to Edinburgh bike, met so many decent folk that are still mates.
Well, probably. Looks promising, anyway. What are the passbands of the drivers as-configured? And their sensitivities? And what is the distance to the listening position? Given the visible toe-in, I'm guessing pretty short, in which case you are likely well covered on the lowest passband. Not as confident about the midbass and domes, which may disperse too widely for ideal projection of forward "club" energy. Would love to give it a listen!You mean like thisView attachment 531249
