NiceHCK Octave dongle DAC
I would like to see some actual measurements of the 3.5 mm output, as I’m fairly sure I can hear unusual sound coloration coming from it (easily reproducible with at least 5 different ciem/iems/headphones I tried). It’s particularly noticeable on vocals, which sound unnatural and seem to have a kind of slow decay, though it’s hard for me to describe what happens precisely. I haven’t experienced this with any other source I’ve tried recently. That said, it could also be an issue specific to my unit.
A review sample of Octave sent by Nice HCK is on my test bench. An actual review may take time, though, as I found weird PEQ behavior and contacted Nice HCK to ask how to proceed. If they want to address it before I write a review, I will let them do that.
hi any news about that?
I only uses the 3.5mm, on the Dune soundtrack I can easily hear the distortion on medium listening level :( particularly awful on the third drop. It is actually more audible than my other cheap dongles.
Actually even some regular tracks I can hear some feint distortions on loud volume listening. Even after tinkering with Low/High gain, the discrete volume and applying -db preamp on EAPO, it didn't matter as either way it only produces superb clean sound only on low volume for me. I ended up just using High gain and -25db preamp, it gives this good fidelity and distortion free then. I'm on latest firmware v1.5, Fast-PC filter.
This is an edit to my previous post
While it's true that I able to hear distortions on low rumble. This can be minimized with the discrete volume control, I just realized this is what it supposed to do.
I have since use Octave with multiple drivers and each one need different kind of adjustments so giving out one settings here is totally useless. Though, I still apply -10db preamp on PC to prevent clipping on Windows mixer. Now it just a matter of how I'd like the volume output after the calibration.
I just updated the firmware to 260113 and checked that it succeeded by looking at the firmware version on Win11 - Device Manager - Octave - Properties - Parent. Working normally on both Win11 and Android, but apparently the low level ticking when idle disappeared, it is perfectly silent now. :) This is checking with 3.5 mm output into Truthear Zero Red, later I will double check with 4.4 mm balanced output into my Truthear Pure. Edit: works fine too.
Great news! Thanks @Donuts123 for letting us know.
Edit: the low level ticking never happened during playback, I tested very silent music and never heard anything. Just when idling.
After the apparent success of the Topping DX1 II desktop mini DAC + PEQ + HP amp, I was thinking that NiceHCK (or TTGK) could also get into a similar competing device based on the Octave. They are already half way there, only needing to add more power, line outs, Toslink in/out and some additional features.
