NiceHCK Octave dongle DAC
@SlowLife - Any idea what FW version is running on this device? Thanks.
You must select Octave under [Sound, video and game controllers].
@SlowLife - I found the firmware version and I am a few builds back from the current release. Two questions, can the firmware upload be initiated from a Windows PC? Where can I download the firmware? Thanks for the assist.
Just go to their website and search for downloads?
Currently, the FW update is only available on Windows PCs.
Hello!
Does anyone know the measurements of the NiceHCK Octave?
I read a review on the Headfi forum from October which stated that "something strange happened when testing the balanced output: it seems that the Octave demands a lot of current for this output. With certain DAPs, or even when connected to a PC, it couldn't reach a high voltage because the device seemed to be blocked." Indeed, the maximum voltage he measured at the balanced port was only 2.655 Vrms at 33 ohms, reaching a power of 210 mW and 80 mA. Has that been fixed by a firmware update?
No firmware update is ever going to fix Head-Fi reviews… :p
I believe the review you’re referring to is from “cqtek”. They speculate about high current demand but did not provide corresponding measurements. The objection to manufacturer power specs simply omits distortion considerations, etc.
After several firmware updates released one right after the other, it seems they have chilled now. Stopped at 251120.
A review sample of Octave sent by Nice HCK is on my test bench. An actual review may take time, though, as I found weird PEQ behavior and contacted Nice HCK to ask how to proceed. If they want to address it before I write a review, I will let them do that.
Has been a while so what is the verdict, Octave worth every penny or if I want to use eq properly I should get …. Better ?
New ES9039Q2M+2xSGM8262+CB5100PRO Portable USB DAC/AMP
I'm guessing it's the same module as NiceHCK Octave [VID_3302 & PID_39C3].
- KINERA CELEST CD-30
[VID_3302 & PID_39C4]
View attachment 507946View attachment 507947View attachment 507956View attachment 507964View attachment 507965View attachment 507969
- ARISYN XUANWU
[VID_3302 & PID_39C6]
https://aliexpress.com/item/1005010731296406.html
View attachment 507977View attachment 507979View attachment 507981View attachment 507982
Wonder if all of those will sound identical to Octave or if they have unique FW which may alter things. After all Nicechk has spent a lot of time revising FW again and again (which mean even if they use same board and only case is different, than FW should be possible to cross install)
I also saw in one review that Octave NO LONGER supports pc version of eq SW?? How true is that I don’t own android
Some company called Comtang sells the board that Octave uses - identical to analog photo board at least
Link
Update - KINERA Celest CD-30 has small windows on front and photo of an open back, and it is NOT identical - some LDO or mosfet and caps/resistors added on it vs taobao board
- I guess maybe photo on taobao is outdated revision, I’m sure manufacturer did some revision of pcb
Can some one open Octave and snap a photo ? Ideally one of recently arrived units
The Octave firmware should be basically the same as the reference (TT39039F01-Pro Max) version. I compared the v1.5 firmware HEX files of the Octave board and the reference board. Apart from the model ID, PID, checksum, and build time (the Octave build is later, but only by about 40 minutes), there are only two places where “37” (reference) is changed to “27” (Octave), which amounts to a one-bit difference. It might be a minor difference such as an LED setting or a default value, and shouldn’t make much of a difference overall.
I bought the reference device in October for $42.50, and it has now been taken off the market.
Never understood why manufacturers do not optimise enclosures - this device could loose over 20% volume if enclosure would be optimised and buttons moved deeper into pcb
I really hope they will make lower power dongle style with no buttons and single DAC + single amp + DSP (emailed Nicechk with idea for “Octave Go” or “Octave Lite” 3.5mm dongle that uses same combo, but single and Optimised for size and weight reduction.
But now I realise they don’t develop anything. Thus I will be emailing ttkg instead I guess they develop those
The public (reference) TT39039F01 ProMax (0x39c2) firmware v1.6 has already been released, so the Octave firmware should be coming soon as well.
In addition, starting from the end of January, all new TTGK firmware versions have switched to a new encrypted API (both HTTP and the firmware itself are encrypted). The previous APIs starting with update. are no longer being updated. I will not make the decryption method public, although I do have a way to decrypt it personally.
Is there a way to configure Octave eq from windows PC or MacOS pc Or iPhone? (Web interface like before)
Because I have all of those but no androids in my house beside smart tv…
Use jeromeof’s devicePEQ as an alternative (you can find it directly under the Equalizer tab here: https://graph.hangout.audio/), or simply flash the TT39039 firmware and then use Walkplay.
For devices that aren’t on the supported list, devicePEQ only enables an 8-band PEQ. You can add Octave’s PID in usbDeviceConfig.js to enable 10 bands.
Amazing thanks in that case Octave has no competition - no other portable dac has properly working PEQ AND mic support in that size or smaller and with THAT QUALITY of sound! Best sounding and technical dac I have heard.
