VyseLegendaire
USB signal isolator + linear power supply—feeding the HS02 I assume…. Why don’t use a good desktop DAC/Amp combo instead of a dongle? Oh, and you’ll only need one USB cable…
not sure if I would spend more than the dongle itself to add a USB signal isolator
I purchased the isolator, other parts mentioned for use with several different DACs from portable to desktop, or all-in-one. Just trying to preface why I could be getting a very favorable impression of some rather budget DACs.
As for all-in-one DAC/Amps or Desktop amp, dac combo, there is still the issue of a linear PSU if you inclined in that direction, while some these do have them built-in its definitely not standardized. Ultimately the same amount of cables will used, plus the audio cables needed to feed a DAC into a standalone amp.
Also I find nearly all non-portable DAC/DAP to be far too powerful if using headphone at approx. 70 Ohm or less. I can get a very comfortable volume at a more moderate position on the dial without blasting my ears off by using an all-in-one dongle.
