Bland_username42069
- Joined
- May 6, 2024
- Messages
- 348
- Likes
- 347
a beauty.Welcome to the linear tracking side of things! Good to have another one.
This is what I have (built from 1984-1986) and this one is shown without the lid.
Check out the tracking error angle the third line down (after it says: Commentary).
Mine also has a rather rare (for the time) 120/60 HZ-240/50 HZ voltage switch, so can use in the same locales as yours.
There are other specs that I cannot compare, as I could not find them for yours.
Audio Database
Technics SL-M3
- ¥ 99,800 (around 1986)
A full-auto player with linear tracking system.
Commentary
It is equipped with a unique linear tracking arm that can make tracking error, which causes distortion during playback, and inside force, which causes channel imbalance, close to 0.
The tracking error angle is within ± 0.05 ° by detecting the arm deflection angle with an optical sensor and obtaining a high-precision detection signal.
The tone arm uses a unique dynamic balance system, and the arm bearing uses a 4-point support system gimbal suspension system.
In addition, the arm has a low mass design with an effective mass of 13g including the cartridge.
Diameter 32.5 cm, Weight 2.5 kg, Inertial Mass 427 kg / cm2Large and heavy aluminum die-cast turntable has been adopted.
Continuously variable pitch adjustment within ± 6% is possible.
Equipped with an electronically controlled full auto mechanism.
Equipped with plug-in connector system MM type cartridge.
TNRC and high-density particle board are used for the cabinet.
Model Rating
Type Quartz DD full auto player system <Turntable portion> Drive system Direct drive Control system Quartz control Number of revolutions 33 1/3, 45 rpm Wow flutter 0.022%W.R.M.S(JIS C5521)
0.008% W. R. M. S (Rotating Part Only)Signal-to-noise ratio 82 dB (DIN-B, IEC98A weighted) Cartridge Section Type Plug-in connector MM type stereo cartridge Exchange needle EPS-P205ED4(¥15,000) <General> Pwer 100 VAC, 50Hz/60Hz Power consumption 22W External dimensions Width 526x Height 202x Depth 426 mm Weight 13.5kg
I keep flirting with the idea of a linear tracker. The last one I had died in a greasy disintegrating mess but when it did work it sounded great.
