orangetang
- Joined
- Oct 28, 2025
- Messages
- 21
- Likes
- 9
Got it, thanks. It's being painted right now... Will look much better!I think it was thin layer of glue and yes it was not so difficult to remove.
Yamaha GT-5000
Underhung has become a thing in the past few years. I've heard that it was originally done for scratch DJs where the the "back cue" would cause a reverse skating force which could be a problem on an arm that had AS. As is usual many reports of sonic bliss but no one will put any evidence forth.
If you calculate the tracking angle error, it's so big that that alone creates a significant portion of antiskating. Tracking angle error can rise easily above 10deg which would indicate that an arm like that should have it's own AS mechanism (that would need to change it's force in direction when the arm crosses the 0deg tracking error)
This is an estimation of the gt5000 arm tracking error angle (depending on where you put the 0 alignment). It's roughly 6 times as bad as your typical 9" tonearm:
I have to admit, I sort of missed that - just stumbled over the article which I posted on the GT-5000 - and it doesn't give much of an insight. Then again, I hold Yamaha in some esteem - and I will see if I can dig deeper, they must have had reasons to do it that way. The arm could have been easily designed differently. Maybe someone who owns a GT-5000 has at least experience to share.
Higher distortion and worse crosstalk, more phase offset if using an elliptical or line contact stylus.Underhung has become a thing in the past few years. I've heard that it was originally done for scratch DJs where the the "back cue" would cause a reverse skating force which could be a problem on an arm that had AS. As is usual many reports of sonic bliss but no one will put any evidence forth.
The last run of the Technics 1200G so if you’re a shellac fan and crippled with audiophile neurosis this sounds like your last chanceTechnics Introduces the Limited Edition SL-1200/1210G Master Edition Turntables
Expensive but lovely, source and more: https://us.technics.com/blogs/news/...ition-sl-1200-1210g-master-edition-turntables
How's your main bearing thrust plate? I'm very much haunted by early examples of these that wore them out in months, the recommendation being to rotate said pad a little once or twice a year... maybe they changed it in subsequent years...The One and Only device in the house with high WAF.
Thanks for your comment. This is first time I hear about the issue. I do not understand how rotating trust plate makes any difference since the bearing in the tube is always in the same exact position? But I will check this when de-assempling the sub frame next time.How's your main bearing thrust plate? I'm very much haunted by early examples of these that wore them out in months, the recommendation being to rotate said pad a little once or twice a year... maybe they changed it in subsequent years...
The thrust plate is the stationary plate/disc at the bottom of the bearing that the hardened end of the main spindle sit and rotates on. I don't think the early ones were lubricated, so pleased that yours is and forgive me associating later examples with the early one that started it allThanks for your comment. This is first time I hear about the issue. I do not understand how rotating trust plate makes any difference since the bearing in the tube is always in the same exact position? But I will check this when de-assempling the sub frame next time.
The main bearing size is bigger in Mk4. It needs to be lubricated well. The only maintenance has been belt- and spring adjustment plastics replacement time to time and oil change in 2006.
I have to have a lid, I despise intricate dusting & I can't blow it into the air with air pressuse & vacumn it up later due to my wife's allergy's.This popped up in my Facebook feed this morning. Nine years ago, I found/bought this Technics SL-D2 at Amvets in Fresno, $50. One of the best, most functional turntables I've owned, equipped with a Shure M44-7 cartridge, perfect for staying in the groove of damaged records. Beauty is in the eye of the beholder, and for me, this one's a beaut. The record on the right is the Australian Jazz quartet, FWIW.
It did come with a cracked lid, but it didn't get used much.I have to have a lid, I despise intricate dusting & I can't blow it into the air with air pressuse & vacumn it up later due to my wife's allergy's.
But, those are wonderful TT's.
