NICE HCK NX8 IEM Review
Rate this IEM:
    Votes: 0 0.0%
    Votes: 4 2.7%
    Votes: 55 37.4%
    Votes: 88 59.9%
This is a review, listening tests and detailed measurements of the NICEHCK (also spelled NICE HCK) "hybrid driver" IEM. It was sent to me by the company and costs US $199.
Not much to say about the looks other than it being a professional one you can wear without worry. A case with different tips are provided. As usual, I wore the larges one for my listening tests (seen above). But for measurement and testing, I used the default smaller silicone tip and default "tube." Company provided alternative "tubes" (filters) but I didn't see a need to swap them out to test. Since it is impossible to seat an IEM the same twice, it would have been futile to do so anyway unless differences are large and in lower frequencies.
NICE HCK IEM Measurement
As usual, we start with our frequency response measurements:
I had better matching between the channels initially but a bit less bass in one. In trying to fix that issue, I lost the synchronicity at higher frequencies. So ignoring the channel differential, we see near excellent match to our target up to 2 kHz. Above that, there is varying but small shortfall. We have to determine preference in listening tests (next section). As a result of this there is not a whole lot to see in our deviation curve from target:
NICEHCK NX8 in Ear Monitor IEM frequency response compared to target measurement.png
What made me fall of my chair was incredibly low distortion:
We are the limit of what we can measure in acoustic protocol at both 94 and 114 dBSPL. There is only a slight rise with 114 dBSP. Bass response is especially impressive.
In absolute level, we also see a clean result:
Group delay is uneventful as it usually is with IEMs:
The two wiggles which also show up in the frequency response graphs is the "rocking mode" of the transducer which shows up in measurements, but not in actual human ears (what I have read but not verified myself).
Impedance starts rather low and then goes way lower:
This could be a concern, requiring a source with good current capability. But sensitively is quite good meaning just about anything should be able to drive it:
My son who helped me with this review and has very sensitive ears, was listening at -50 dB on the Topping DX5II DAC/Amp!!!
NICEHCK IEM Listening Tests and Equalization
Stock performance was impressive. Bass was deep and authoritative (for an IEM). Detail and overall tonality was right on the money, making my reference tracks sound even better than I remembered! Still, there is the question of the small variation in treble so I created a few filters:
Band 2 made the spatial impression go from good to excellent (again for an IEM). The one at 13.2 kHz was inaudible to me. I performed AB tests of the whole set. While the filtered provided more of a fun factor, on anything with good bit of treble sounded too sharp. This is after me dialing them down good bit as you see above.
I had my son perform a blind test on his own and he too preferred the stock tuning. So I would say filtering is not needed.
I must say, I went into this review with very low expectations. I had not heard of the company or its product so didn't think they had done much tuning. I thought they were just selling the basis of marketing buzzwords (hybrid, "8 drivers"). What I measured and heard was exactly the opposite. The NX8 is a very fine tuned IEM with delightful yet accurate tuning. Yes, the price is higher than our budget alternatives but there is a difference here, especially in distortion and somewhat on tonality which you may prefer.
I am happy to recommend the NICE HCK NX8 IEM.
  • 8 Drivers Hybrid IEM In Ear Monitor Headphone
  • 1DD + 6BA + 1Piezo Units
  • VGP 2025 Summer Awarded
  • High-Precision 3D Printed Resin Cavity
  • Luxury Galaxy Pattern Personalized Faceplate
  • The latest NiceHCK NX Series IEMs
Bigger concern than current capability is output impedance I'd say.
Even if the headphone Amp has plenty of grunt, any output impedance higher than 2Ω or so will cause the treble to drop even further below target, making the NX8 sound duller.
Thanks for the test, @amirm!
That's impressively good distortion for something using BA drivers.
I've come to expect BA and BA hybrids to measure >= ~0.5% THD in the midrange at <100dBSPL even on units costing many hundreds of dollars.
Can still see signs of elevated third harmonic in the midrange, but at such a low level it doesn't matter.
I'm curious which brand of drivers they are using.
Very nice. Much like electronics, IEMs look like they are a solved problem.
At least with respect to these things that can easily be measured. I'm still trying to figure out why my Salnotes Zeroes cause so much noise when I put them on. I can hear my blood rushing and pumping, any movement of my jaw, etc. I've tried tips of many sizes. It's not the cable because I get the same thing with the cable disconnected. I don't get this with my Airpod Pros or my Moondrop Space Travels. I'm guessing the wide nozzles press directly against my ear and don't allow the tips to "float." Second possibility is that the unvented design causes issues.
So bringing it back to these earbuds, what do the nozzles look like? And is it vented or fully sealed?
Nice distortion performance! They also seem to have pretty good tuning, which is very close to my personal preference (for 711 coupler measurements at least) of Harman in bass but a bit less in the ear gain (2-6khz) region. I would like to see a couple of those lower to mid treble peaks (or maybe they're dips) smoothed out, but they're likely not a large problem if any. If I had more normal sized ears I'd probably end up with either these or the Crinear Daybreak (I got to personally demo those at CanJam SoCal, and they're pretty much perfect for my preferences). As it is, all I can do is admire the first BA based IEM I've ever seen excellent distortion measurements from.
I do have my doubts about the elevated distortion on many BA IEMs being audible under most conditions, but this is still good engineering to overcome such a prevalent issue.
@amirm or others, do we know much about the fit and comfort? My Salnotes Zero Reds are great but head movements cause them to need pushing back in with any of the tips I use. Looking for a replacement and this might be it.
NiceHCK is known in China by its Chinese name, Yuandao (原道). To Chinese audiophiles, this brand carries enormous meme energy.
Originally, the company got its start making ultra-budget flathead earbuds (the old-school ones, not IEMs). Some of their most iconic models were sold on Taobao (China's largest e-commerce platform) for the mind-boggling price of just 9.9 CNY (roughly $1.40 USD) with free shipping. These were quite possibly the cheapest earphones on the planet that could be described as anything approaching "Hi-Fi" with a straight face. For countless Chinese students, young workers, and budget-conscious hobbyists, Yuandao's 9.9 CNY earbuds were their very first gateway into the world of audiophile listening. And the astonishing thing was: they didn't sound like garbage. They sounded competent, even pleasant.
This origin story gave birth to one of the most enduring and beloved memes on the Chinese audiophile internet:
"If only I'd known sooner, I should have stuck with Yuandao all along."
Here's how the meme typically plays out: someone on a Chinese audio forum posts about spending $2,000+ on some flagship headphone, expresses mild disappointment, and is immediately met with an avalanche of replies: "If only I'd known sooner, I should have stuck with Yuandao all along."
The joke escalates to absurd heights. Chinese netizens routinely produce satirical "comparison reviews" pitting Yuandao's $1.40 earbuds against Sennheiser HE-1 / HE90. The punchline is always the same: Yuandao wins. Obviously. :)
At some point, the meme brand decided to grow up. Yuandao (now marketing internationally under the name NiceHCK) began pivoting away from bargain-bin flatheads and into proper IEMs. They started releasing products that weren't just good for the price of a bottle of water, but genuinely competitive against established Hi-Fi brands.
It seems that after years of jokes, the prophecy has finally come true: Yuandao really was the answer all along ;)
I can't speak for anyone else as that is highly personal. Did want to comment that they were comfortable for me. They are not oversized or heavy. And replacing tips is very easy so you can easily experiment.
Guess my question is what precisely do all those drivers do that a single driver can not? Moreover what does using all these different types of drivers add to the overall effect? Maybe there is someone with more experience than me in the IEM niche of this hobby who can supply the received wisdom on that?
As always, nice review Amir.
Personally these look nice as well. going as they do for that "cuff link in the ear" look, but they're a little too "Harmany" for my personal taste. Would be interesting to see this one with a Meta tuning.
It amazes me that they are able to fit so many drivers in such a small body, let alone being able to measure and perform so well!
Thanks Amir, and keep the reviews coming. The more you review the quicker my unit will get it's turn. :)
If only all IEMs had this level (or lack thereof) of distortion!
Thanks @amirm!
Here are some thoughts about the EQ.
Please report your findings, positive or negative!
Notes about the EQ design:
  • The average L/R is used to calculate the score.
  • The resolution is 12 points per octave interpolated from the raw data (provided by @amirm)
  • A Genetic Algorithm is used to optimize the EQ.
  • The EQ Score is designed to MAXIMIZE the Score WHILE fitting the Harman target curve (and other constraints) with a fixed complexity.
    This will avoid weird results if one only optimizes for the Score, start your journey here or there.
    There is a presentation by S. Olive here.
    It will probably flatten the Error regression doing so, the tonal balance should be therefore more neutral.
  • The EQs are starting point and may require tuning (certainly at LF and maybe at HF).
  • The range around and above 10kHz is usually not EQed unless smooth enough to do so.
  • I am using PEQ (PK) as from my experience the definition is more consistent across different DSP/platform implementations than shelves.
  • With some HP/amp combo, the boosts and preamp gain (loss of Dynamic range) need to be carefully considered to avoid issues with, amongst other things, too low a Max SPL or damaging your device. You have beed warned.
  • Not all units of the same product are made equal. The EQ is based on the measurements of a single unit. YMMV with regard to the very unit you are trying this EQ on.
  • I sometimes use variations of the Harman curve for some reasons. See rational here and here
  • NOTE: the score then calculated is not comparable to the scores derived from the default Harman target curve if not otherwise noted.
  • Occluding IE devices generally must have very good fitting/seal in the user's ear canal for best performance.
    please spend a few minutes to pick up the best ear tip... Be sure to perform this step otherwise the FR/Score/EQ presented here are just worthless.
  • 1. more bass = better seal
    2. More isolation from the outside world = better fit
    3. Comfort
Good L/R match.
I have generated one EQ, the APO config file is attached.
It is probably over the top.
The first Biquad can safely be ignored, there is always a bot of leakage in a real ear therefore having a bit too much very LF is fine...
Score no EQ: 80.0%
Score Amirm: 79.7%
Score with EQ: 97.1%
Code:
NICE HCK NX8 APO Full EQ Flat
March032026-145129
Preamp: -5.60 dB
Filter 1: ON PK Fc 21.0 Hz Gain -1.93 dB Q 1.35
Filter 2: ON PK Fc 231.9 Hz Gain -1.90 dB Q 1.86
Filter 3: ON PK Fc 1402.1 Hz Gain -2.09 dB Q 1.99
Filter 4: ON PK Fc 2669.9 Hz Gain 2.68 dB Q 3.59
Filter 5: ON PK Fc 4529.9 Hz Gain 1.94 dB Q 6.00
Filter 6: ON PK Fc 6615.9 Hz Gain -3.55 dB Q 5.99
Filter 7: ON PK Fc 8946.8 Hz Gain 6.58 dB Q 2.05
Filter 8: ON PK Fc 12950.9 Hz Gain -9.01 dB Q 4.26
Thanks Amir, and keep the reviews coming. The more you review the quicker my unit will get it's turn. :)I
I wondered the same thing and briefly read up on balanced armature drivers. Seems they are very small and sensitive. Not really sure why they would be better than one or two voice coil actuated drivers, but since one can use many, maybe think of them as active metamaterial drivers or magnetostatic meets meta. Just think of a few dozen of these living in the back of a KEF tweeter with a DSP and a bunch of amplifiers driving them...
In the end really, why would you need them if you already have the Zero 2 or something like that? I would consider these only if they were more comfortable to wear.
