After buying a miniDSP umik I've gone down the rabbit hole of speaker placement and trying to correct what I believe are nasty room modes and SBIR, but have one in particular that doesn't seem to respond too differently to speaker location.
I have a pair of KEF 104/2s placed in a condo living room, which includes a staircase, dining room, kitchen - a large, non-rectangular volume. The speakers aren't centered along the wall they are against, with the back of the left speaker 23 cm from the rear wall and the left side 75 cm from the left wall. The back of the right speaker is also 23 cm from the rear wall and the right side is 152 cm from the right wall. There's no specific room treatment and unfortunately the most convenient listening position is ~400 cm away from the speakers and about halfway along the long axis of the room.
Below is the left (red) and right (blue) speaker RTA measurement with full range pink noise before applying any DSP correction with var smoothing. Low frequencies are slightly boosted and there are large nulls in the right speaker near 65 Hz, 150 Hz, and 300 Hz. I swapped the left and right speakers to make sure it wasn't a driver issue and confirmed it's location and not speaker dependent.
Below is the left (green) and right (orange) speaker RTA measurement with full range pink noise with DSP correction to 500 Hz and a slight bass boost, avoiding nulls and in particular the right speaker drop around 60 - 70 Hz. I also have a set of filters to 1k since there seemed to be some issues beyond 500 Hz but have not measured this one yet.
DSP is definitely an improvement in tonal balance after knocking down some of the low frequency peaks, but that massive null in the right speaker bothers me and I'm curious if there's other feedback on these measurements. Any suggestions or recommendations are appreciated!
