You know, I was just reading the Ascilab C8C review, which you can pair with the BX8C. That would be an all-in-one solution, and look a lot cleaner and would be pretty state of the art right now. Also curious what the floorstander will be capable that they plan on releasing. I only got the subs to fill in the low-end that the F206 can't quite reach and would in the end much prefer the cleaner look of just 2 towers that go all the way down to 20hz.The main reason I could think to upgrade from F206 is to get speakers that play the lowest octave and give you opportunity to eliminate the subs. F206 is an amazing speaker.
At the risk of being redundant, I'm another kh150 lover here. I'm not sure of the why, but they're my best investment in audio gear and trump everything else i got, praise to ASR and @amirm for putting them on my radar.Yes the imaging and detail on the KH150 is really a step up from the Revel. Really next level.
Agree completely. If/when I ever have the money for speakers like the C8C it will be the time to upgrade.You know, I was just reading the Ascilab C8C review, which you can pair with the BX8C. That would be an all-in-one solution, and look a lot cleaner and would be pretty state of the art right now. Also curious what the floorstander will be capable that they plan on releasing. I only got the subs to fill in the low-end that the F206 can't quite reach and would in the end much prefer the cleaner look of just 2 towers that go all the way down to 20hz.
www.audiosciencereview.com
Ha! Well this house I'm moving in has two living rooms (one in the back, one in front), and this setup will be in the room where the TV is. The other room, I dunno, I might buy a Sonos if I want some music there and am just relaxing. So that A/B might certainly do the trick as well haha. (Sonos is meh, but I also don't want to spend more than a few hundred bucks to have some audio in the other room).you want a slightly different take?... stop listening to the revels for a month... the goosebumps will magically re appear when you listen again..
my thought was to help you gain a frame of reference.. what you have now is pretty darn good, and secondly frame the thought that audio listening isn't a competition.. there is no need to "keep up", especially with anyone else... best of luck , the Sonos may work out as well....Ha! Well this house I'm moving in has two living rooms (one in the back, one in front), and this setup will be in the room where the TV is. The other room, I dunno, I might buy a Sonos if I want some music there and am just relaxing. So that A/B might certainly do the trick as well haha. (Sonos is meh, but I also don't want to spend more than a few hundred bucks to have some audio in the other room).
It's starting to sound more like a common case of Audiophilia Nervosa.You know, I was just reading the Ascilab C8C review, which you can pair with the BX8C. That would be an all-in-one solution, and look a lot cleaner and would be pretty state of the art right now. Also curious what the floorstander will be capable that they plan on releasing. I only got the subs to fill in the low-end that the F206 can't quite reach and would in the end much prefer the cleaner look of just 2 towers that go all the way down to 20hz.
I might try the Dirac Live that I can install on the miniDSP Flex for my 2.2ch listening setup. Had done it manually with REW + MSO and overall didn't get results I was completely satisfied with. It's just the basic Dirac Live, the minidsp doesn't support Bass Control or ART. Should still be good enough, right?Would be good to know which passive towers will go down to 20hz at say, 100dB and some acceptable distortion, say 20%. At the same time, write off the woofer clean response at say, 100hz, which is usually still half-way to crossover. So if such speaker exists, which I am not aware of, then you still get worts of both worlds.
Subs were made for a good reason and they work really well with proper integration.
Well not really. REW and MSO should be able to do better than Dirac Live. It just is very difficult to manually integrate subs. I never tried MSO as was not fitting in my setup, but graphs and results other people got with MSO were really impressive.I might try the Dirac Live that I can install on the miniDSP Flex for my 2.2ch listening setup. Had done it manually with REW + MSO and overall didn't get results I was completely satisfied with. It's just the basic Dirac Live, the minidsp doesn't support Bass Control or ART. Should still be good enough, right?
