Newbie trying to set up a subwoofer with my speakers using REW
Ttimms
Hi all, I'm trying to integrate my SVS 3000 Micro subwoofer in with my Dali Oberon 3 speakers. I'm using a Loxjie A40 amplifier. I'm new to using REW but I've taken a few measurements at seating position with an ECM8000 mic of various crossover points. Looking at all the crossover measurements I've found that 75hz and 24db slope on the subwoofer gives the best response (24db slope is suggested with Dali's as they are ported) however at seating position I'm noticing weak bass in the 70-100hz range and it sounds like the bass is bouncing from the left and right side of me. I've tried using a 12dB slope at 60hz and it sounds much better but it looks worse on the graph? Looking at the measurements the 75hz 24dB slope (red line) compared to 60hz 12db slope (yellow line) is better, right? but to me it sounds much worse. Does anyone know what is happening here? for reference I have attached a measurement of just the speakers with the subwoofer off.
Dali Oberon 3 claims -3dB at 47Hz, which is quite low for a bookshelf, but this is probably measured in an ideal room (or none) and ideal position against the wall. The speakers have a rear port (only way to extend bass-end in a bookshelf, so will interact with the wall behind quite a lot.
If this was me, I'd block the rear-ports with a foam plug, and re-do the measurements - for the purpose of test. This will push the -3dB point of the Dali's up quite a bit, but you should be able to compensate for this with the sub(s), and without as much complexity from the port. Leave the amp flat. The amp has plenty of power - the Dalis are criminally 6 ohms, but I don't know anything about how it uses REW results to set up filters.
I wouldn’t get too hung up on which graph looks better. If the 60 Hz / 12 dB setting sounds better, I’d trust that and start playing with placement and phase around that 70–100 Hz area.
