Tone wise is not a great translation. Try both in your own room....Ah i see KEF Q11 Metas measure better than R11 Metas tone wise?
unfortunately i am located far away in Asia..where are you located? i have a pair of monitor audio silvers that i'm not using but outside of boston, usa, the shipping is likely to be expensive!
Might be best to list what you can access within your budget, especially with an in-home trial.unfortunately i am located far away in Asia..
I dont think dealers do in home trial in Singapore, i have booked a few demos to listen to the Mofis /REFs/ Revels tomorrow. My budget is in the 5-7k USD range.Might be best to list what you can access within your budget, especially with an in-home trial.
Unfortunately nobody carries Ascends/ PH BMRs here so i am unable to demo them. So far have demoed Monitor platinum 200 3g and am really impressed with them. Less so with SVS Titan comparatively.I dont think dealers do in home trial in Singapore, i have booked a few demos to listen to the Mofis /REFs/ Revels tomorrow. My budget is in the 5-7k USD range.
Too bad. I'd concentrate on Revel then Mofi....REF is what?I dont think dealers do in home trial in Singapore, i have booked a few demos to listen to the Mofis /REFs/ Revels tomorrow. My budget is in the 5-7k USD range.
Apologies, i mean KEFToo bad. I'd concentrate on Revel then Mofi....REF is what?
I have several older Ascend models, like them a lot. Newer ones would likely be even better. Monitor no experience with, not a big brand IMEUnfortunately nobody carries Ascends/ PH BMRs here so i am unable to demo them. So far have demoed Monitor platinum 200 3g and am really impressed with them. Less so with SVS Titan comparatively.
Not impossible at all, you can check the "compare" page of spinorama. If you are considering bookshelves as well, the recently reviewed Ascilab C8C (active) is now the champion of the ranking. Its bass extension is comparable to a floorsander. Same for Audio First Cadentia, very good looking and passiveAh i see KEF Q11 Metas measure better than R11 Metas tone wise?
