AndyBell
- Joined
- Nov 16, 2025
- Messages
- 32
- Likes
- 37
Hi all
I bought my audio gear based on reviews I read before finding ASR. I probably would have bought other equipment if I had read the info on this site first.
Anyhow, my setup is this:
I live in a flat and my audio room is a small room I also use as my office. I can’t pump up the volume much as the neighbours wouldn’t appreciate it, so I listen mainly at around 70db max with occasional sessions at 80-85db (I have a decibel meter)
My gear is:
Windows 11 PC + Neutron music player
FiiO K11 R2R via USB
Or
Samsung Galaxy A16 + Neuton connected to the K11 via Bluetooth using FiiO BT13 LDAC
Music is FLAC ripped from CDs. Mainly 70s prog rock and ‘meaty’ classical such as Beethoven.
Argon Audio A5 speakers
I also have Sennheiser HD560s with a balanced cable that plugs into the K11 and gets good volume.
I use the same settings for the Neutron audio player on the PC and the A16: no upsampling, some EQ to boost the bass as I like a ‘bassy’ sound.
To my ear, it makes no difference if I use the PC or the A16. The advantage of the A16 is not having to boot up the PC. But it sounds the same.
I have tried the K11 in both OS and NOS modes and can’t hear any difference. My understanding is the K11 in NOS mode still applies a low pass filter, which may explain why I can hear any difference. Or it could be my hearing - I’m not young and a hearing test shows I can hear up to 16khz.
Given that background, would I gain anything by replacing the K11 + BT13 with something like a Topping DX5 II? I like the sound I get with my equipment but the reviews on this site indicate the K11 R2R isn’t state of the art and measures less well than the Topping (and a lot of other gear). But would I hear a difference?
Andy
My gear is:
Or
Andy
