NEWBIE : Any difference between Linux Music Players ?
PenguinMusic
HI,
Currently using Linux to listen to music (Manjaro distro).
I have set it up so that sound does not use PulseAudio, but uses JACK that interfaces directly on ALSA (at least from what I have understood).
But that is not the question here...
I do no changes to the system audio configuration at all.
So every sound output is routed the same way that is, as mentioned, using jackaudiosink.
I can play my music through different music players : Lollypop, gusicbrowser, Strawberry, deadBeef, Quod Libet.
My question is simple :
"Can the used player have a different output despite the fact that is uses the exact same output configuration or should they all sound exactly the same ? "
PLEASE CONSIDER :
- I am not asking which player to use.That is highly subjective/personal taste.
- I am also not asking if I should use PulseAudio, ALSA, oss, MPD or JACK. I will find my way out of this by myself.
P
PenguinMusic
Hi,
Thanks for your answer.
I should have mentioned that :
- ReplayGain is turned OFF in all players ;
- that I use NO EQ in any player ;
- that volume of ALL Players is set to 100%.
I do not know what dithering is though.
solderdude
The Neitherlands
When properly designed they should output the same sample values. If not they, for whatever reason, are changing the values of samples.
P
PenguinMusic
Hi,
Thanks a lot for your answer.
So, as long as I don't "play" with RG/Volume/EQ or any other "sound improvement" setting, all should output the same sound from my .flac files.
Can I get to the conclusion that in the end it is only a matter of tastes and need of features that makes you choose a player over the other ?
Regards.
somebodyelse
You could actually record the output from each and check. Since you're using jack you can use one of the patchbay apps instead of messing with the alsa config files.
