New wireless headphones
Medsca
My Bose QC 45s finally died. I’m in Search of a new set of Bluetooth over the year headphones that are not very bright.
I presently own Sennheiser HD 650 and DCA Aeon RT closed.
What would you pick and why as a wireless set of new over the ear cans?
When my QC35s die, I’ll probably buy Bose again, but not without considering Sony first.
As an iPhone user I’d also be inclined to buy the AirPods Max 2, but only second hand, it’s just too expensive for me
Outside of these three, I’m not sure who else gets the overall package right (sound quality/build quality/usability/comfort/ANC). There might be a Samsung/Harman or Sennheiser alternative I’m not aware of
Sennheiser Momentum 5 or Bose QC Ultra Gen2 or the new Sony XM4 refresh
Sony XM6.
Price should have come down by now.
I had almost all Sony XM over the years and prior to them Bose. The XM6 is IMO the one where they got everything right. Best ANC, everything properly sized and fitting, best sound of the series.
The other one to look at is the XM4. That was also very good with a lot of options from Dekoni, EQ profiles.. for what it costs now a very nice one.
I left Bose ANC long ago, from what I hear their ANC is inferior to Sony. The early models were good sounding (bose boomy) over Sony. That has long changed. All the XM are heavy on the bass and EQ always free that up when going for a linear response. A matter of taste.
Odd one: I also have a Dali IO-6. ANC can't compete with Sony, but sound quality is there with the XM4. No LDAC. Good quality and fitting, could be a good cheap option.
I’d go with the latest Sony for all around tech, comfort, sound.
Sennheiser for just sound but I’ve heard the latest are quite bass heavy, which could be good or not depending on preference.
Also interested in Moondrop Edge2 but haven’t really heard much about them.
For another lower cost option JBL Live series have been overall, pretty nice but probably won’t match any of the other top brand models for overall performance but hold its own at usually less than half the cost and might have the best battery life if that’s important.
I replaced my QC35s with the AirPods Max 2, mostly because I like the Spatial Audio with head tracking thing with the Apple TV. I like them and had no issues whatsoever. It felt like a good upgrade over the Bose.
Wireless headphones: now we're talking. Both pair of my older Sennheiser's are great, the are not Bluetooth (they are on the old cordless phone frequencies). I have a 30 meter range (allowing me to ride the lawnmower: while listening to music being played from my home.
The freedom to listen while doing anything in my yard is great.
My Bose QC 45s finally died. I’m in Search of a new set of Bluetooth over the ear headphones that are not very bright.
Lewitt LW6
reason: seems to be what I would buy if I did not have a (wired) HD 480 PRO.
The Sennhesier Momentum series has been great value for features and sound quality. I'm very happy with my M4s and I've heard good things about the M5. User replaceable battery on the M5 is a big plus.
I bought the Bose QC 35 about 5 years ago and I can't fault them, but for 1 minor thing. Sound quality with anc on is great, they're light, fold into a small hard case. The only point that can be improved upon imo is the microphone quality, it's a bit like hearing someone in an empty room (low bitrate ? ).
I would personally consider and try the Ultra wireless headphone if it's only for home use.
I'm considering the Sennheiser HDB 630 because it seems to be quite the Swiss Army knife of wireless over-ear headphones.
Moondrop Edge 2 for superb stock tuning and drivers/hw that deliver and comfort but not for ANC or mic quality.
