New Turntables - AT-LP8X, DP3000NE, SL-1300GK, and others
Looks like Technics turntables made in Malaysia just got hit with price increases based on 24% tariff versus the actual - current - 19 % that went into effect August 1st.
A few vendors still have units at the prior pricing - probably will change after restocking if not sooner. Glad I bought when I did!
17 'tables here presently. Likely I'll stay with one of the SP-10MK3. Speaking of, the 10R could probably go too.
How many do you have set up versus on the storage shelf.
That's why it needs testing. The test of the 3000NE showed better than published specs. The "less than" spec can be a little or a lot less. On the other hand, those specs may be "good enough" for most.
I have made kind of a point of clarifying the "LESS THAN" spec of Audio Technica turntables - I am a fan, and after testing, still prefer the highest models to the equivalent Technics ones - tried the 100C and the 1500. NOT saying that Technics are not great tables, but my experience with the devices and the company has been way better with AT.
That said, yes, the spec says LESS THAN. AT specify all of their turntables like that. A hifi magazine ( Australian HiFi I think ) had an independent lab test the W&F on an AT turntable, the LP7, I believe. The W&F value way lower that the LESS THAN value on the spec, about the same to what is deemed a good value. That said, I cannot find the article anymore, will try to look for it and update this comment if I find it.
That situation has made me wonder whether most turntable manufacturers specify an average value or even worse, a best case value, while AT is honest enough to account for variations and not deceive their customers. IF (I might be wrong) that is the case, I respect them and like them even more.
I decided on an SL1500C . Tried 4 units - 3 had wobbly platters and 1 had a machining ding on the front of the plinth casework.
Really poor QC from my own experience
and seems like platter issues are commonly found online when searching. Probably not audible , but cosmetically not really acceptable.
Such a shame as I really wanted this TT. Not sure what to try next :(
wobbly platters: not acceptable. A machining ding? Maybe, maybe not. If it can be rotated out of site when not in use. But, somethings get stuck in one's head, even when they are out of site. So...
I'd keep looking, as that is a quite good and generally trouble free TT. KAB would also be a place to look, as they may have some custom rebuilt ones.
KAB Electro Acousticshttps://www.kabusa.com
[td width="52%"]
KAB New Technics SLV Mod Package $553.00
[/td][td width="47%"]
Click To Buy
[/td]
[td width="52%"]
KAB New Technics BLK Mod Package $553.00
[/td]​
Just wanted to update some useful info re the AT LP8X wow and flutter spec. I asked AT Support about the rather conservative value (0.1) vs the SL1500C value of 0.025
The response is that the AT measurement uses a weighted quasi-peak measurement method, which is intentionally conservative and produces higher numbers than the WRMS method used by technics.
ChatGPT confirmed this - and suggested the weighted quasi-peak measurement method gives wow and flutter numbers that are 3-4 times higher than a WRMS measurement on the same turntable - so 0.1 vs (0.025 x 3/4) doesn't look so bad .
I'm no expert on this so happy for folks to chip in with their opinions .
Really impressed by the speed of response from AT in the UK also (within two hours)
Also understand the LP8X is servo controlled and not quartz locked like the technics table
Thanks for the info. So the AT-lp8x is .1 and the SL-1500C is .01875? That still seems like a bit of a difference. Btw the lp8x is on my list of forever turntables but this number doesn’t narrow the gap.
My Technics SL-M3 has these figures in the manual (Is there a way to convert the WRMS figure to the weighted quasi-peak measurement value)?:
Technics SL-M3​
Quartz Controlled Direct-Drive Fully-Automatic Turntable System (1984-1988)
review this turntable (1 review)
with linear tracking tonearm
Technics SL-M3
Specifications​
Type: fully automatic
Drive method: direct drive
Motor: brushless DC motor
Drive control method: quartz phase locked control
Platter: 325mm, 2.5kg, aluminium die-cast
Pitch control: +-6% range
Speeds: 33 and 45rpm
Wow and flutter: 0.022% WRMS
Rumble: -82dB
Tonearm: dynamically-balanced linear tracking
Effective length: 238mm
Effective mass: 13g (including cartridge)
Cartridge: moving magnet
Replacement stylus: EPS-33ES
Dimensions: 526 x 205 x 425mm
Weight: 15kg
I just received my LP8X today. I’m pretty impressed. I didn’t try the cartridge it came with. I put my OC9XLS on it. The interconnects it came with measure around 50pf of capacitance. I fell out of love with my PLX-1000 and decided to try something different. The LP8X seems dead quiet. The arm has no noticeable play in the bearings and is very free feeling. I did a W&F test with my “Ultimate Analog Test Record” and the NAK100 app. Speed was dead on. Quasi peak W&F was around .9 and weighted RMS W&F was bouncing between .03 and .04%. Some of that has to be cooked into the LP so true numbers will be less. How much? Who knows but it’s already pretty good. Didn’t get a low end Technics because I read too many reports of warped or wobbly platters and unreliable auto stop. I had a fancy mechanical tonearm lifter on my Pioneer and about 25%of the time I’d forget to cock it and the tonearm would run into it halfway through the record. That’s even more annoying than listening to the trapped groove at the end. The push button cueing is slow and smooth. Reminds me of the DP37F I had back in the day.
Technics 1300g vs Denon 3000ne. From German magazine. Articles states 2S wow&flutter at 0.05% for both. And one magazine state Denon 3000ne to be the second best speed stability ever measured,,, we can guess who was the best. Anyway Denon seems to be an OK choice compared to the market reference Technics. So it comes down to personal preference, considering the platter stories about Technics and poor Technics response and tag fact that I am a a Fan of old Denons, I will lean towards Denon if I get a good offer..
Denon 300ne
Test records are notoriously unreliable and off center making the results highly uncertain..peak wow of 0.9 is very very high , probably a off centre record. try a phone app.RPM WoW here
A good record would look like this on NAK
Same TTas above Denon 51F, B&K QR2010 record, centred
Reactions: EJ3
You said peak wow of .9% is very very high. I meant to type .09. Then you show weighted rms readings from a phone app of .04 which is what I was getting from a test record. A phone sitting on a turntable doesn’t measure flutter so all you have is wow. Your NAK picture shows .02 weighted rms (not peak) while my reading was .03 to .04% weighted rms which was undoubtedly higher than actual due to the errors inherent in the record itself. I already mentioned that above. I tried that phone app and then deleted it. Something for vinyl newbies to play with but hardly accurate. The bottom line is that this is a very nice record player. Finding an old high end Denon that works like new and still looks good is probably equally expensive, has no warranty and zip parts availability. I have tow vintage belt drives. I won’t buy an old direct drive because of the likelihood of an unrepairable failure.
