You do not need 10 awg for a run of only 23 feet. 14 awg will be just fine and 12 awg would be overkill but still easier to get than 10 or 8 awg.Thank you, what would you recommend between 8 awg and 10 awg to buy 100ft on Amazon?
Ok That's exactly what I wanted a spool for. If 12awg is enough, could you tell me a place and brand to buy it? I mentioned one I found on Amazon above, but it wasn't recommended. Thanks.What do you mean "box cables"? You mean buying cable in bulk in a reel or something? I buy 12g that way for that reason, suits any situation I have well. I have typically purchased direct from Monoprice, altho sometimes they do sell thru Amazon.
Same company GearIT has regular copper in 12awg as well as CCA if that brand is easy for you to get in your location.Ok That's exactly what I wanted a spool for. If 12awg is enough, could you tell me a place and brand to buy it? I mentioned one I found on Amazon above, but it wasn't recommended. Thanks.
This good ?
I don't use the CMP rated but that would work fine. I've purchased several hundred feet of this style https://www.monoprice.com/product?p_id=2747Ok That's exactly what I wanted a spool for. If 12awg is enough, could you tell me a place and brand to buy it? I mentioned one I found on Amazon above, but it wasn't recommended. Thanks.
This good ?
2.5mm2 or 4mm2 copper cable. Cheapest you can find. Just make sure its not CCA.I just bought a new system and while I'm an experienced and discerning musician, I'm new to audiophile equipment. Budget is flexible. What speaker cables would you recommend, from experience? As of now, I'm considering Cardas Cygnas or Clear Reflection. Someone suggested Synergistic Research as a line to look into, speakers are cornwall IV - high efficiency and horn forward of course.
PASS Labs XP20 Preamp>PASS Labs XA30.8 Pwramp>Cornwall IV speaker
The speakers have a 4 post biwire setup, would biwire speaker vs jumpers be suggested and what speaker cable would be a good match for this system? I listen to mostly live music recordings, grateful dead, phish, etc.
I know- But any brands have thinner insulation/cover than others?The gauge is defined by diameter, excluding the insulation.
I understand hating to drill holes in your floor. It sucks but sometimes it’s the only way. Be careful the hole is large enough though that the wire glides through it without so much friction it causes stress on the cable. Generally cheaper brands will use less insulation but really I wouldn’t overthink it too much. The difference in most brands is going to be pretty minor and you’re still stuck with a hole in your floor.I know- But any brands have thinner insulation/cover than others?
