killdozzer
I've been through a lot and lost all I had so I had to start anew. Silver lining is, this made me realize how much you can do with a few hundred bucks these days. Here's the system (warning, it's a bit "Freshman-like"):
Just a small living room, but in this case the dimensions helpped. No matter how basic the Yamaha sub is, in-room response I can measure 30Hz quite audible. I was sending low freqs and tried to measure them, even a very quiet 20Hz was audible, I'm guessing -10dB. I was lucky that empty little corner right next to my doors also makes it sound really good. It's smooth, not a "one-note" boomy fill, scales up and down, it's quite soothing. I may experiment a little bit to see if there's even a better placement, but this will do for now.
Watching Project Hail Mary... The entire room really rumbles nicely when needed. The other thing is, these small KEF speakers. These are the IQ10s, it was the smallest model in the line for that year of production. Still, they do play audible 50Hz and even 40 slightly less loud.
The Yamaha Receiver I'm using is the RX-V795a RDS. More than powerful enough (much more, in fact) for such a small room and relatively speaking, undemanding speakers. A tiny, tiny peeve I have with it is that it has a fixed frequency filter set at 90Hz on the Sub-Out which is more than I would send to the sub and the mains are quite capable of playing 90Hz. OTOH, it looks like out-of-the-box, really well kept and it came with the original remote. Works like a charm.
Still, if one has time and is willing to play around with it, it can sound amazing (or at least amazing for the money). The records are the biggest surprise. I think sub really helps them sound better. What you're left with is tone controls, "Bass-Extension" button and the volume on the sub to dial it in. The sub has no other controls, it is really basic. Bass-Extension is like Loudness and you can find in the manual exactly how much dB it adds and to what freq. I was going by ear.
I'm playing my stereo in 2.1, same as movies and I get a feeling of a full-range system (almost). The 90Hz cut-off still works well enough not to be able to locate the sub. I guess It was more luck than smarts, but the sub really melted away behind the mains and it feels like the lows are emitting directly from those small KEF mains. It has some oomph for the EDM, and nice smooth bass for the bass guitar. I really like it.
Next step is to add the NAS with my music library and I'm good to go.
