Subwoofer :20 Hz to 80 HzThis is a woofer, not a "sub" woofer.
Iloud Sub: 25 - 150 Hz @-6 dB
At my listening position: 25 Hz @ 0 dB
I think it's a subwoofer
My interface only has TRS outputs, and I'm not really interested in sourcing some RCA adapters. The ARX X software makes the calibration appear a lot flatter than the REW measurement. The pre-calibration curve >50 Hz (i.e., sans sub) accords well with the REW measurement. ARC X is generating the pre with the actual measurement. The software doesn't perform another measurement after calibration, so we know the post curve is a simulation.1. Did you try using RCA instead of XLR?
2. What did the ARC graph look like? Because that 220Hz peak is striking, and you might see it in REW but not in ARC.
3. You can see the classic KRK 2/3kHz drop and 10kHz rise, and it seems ARC didn't agree with that, haha.
4. And as in almost all cases, the sub reaches 25Hz.
Perhaps try testing with another source (CD player, cell phone, etc.) to rule out the cable or the subwoofer input as the problem.My interface only has TRS outputs, and I'm not really interested in sourcing some RCA adapters. The ARX X software makes the calibration appear a lot flatter than the REW measurement. The pre-calibration curve >50 Hz (i.e., sans sub) accords well with the REW measurement. ARC X is generating the pre with the actual measurement. The software doesn't perform another measurement after calibration, so we know the post curve is a simulation.
It makes intuitive sense that the two measured responses match better than the pair of (optimistically?) simulated and measured responses.
I think it's a good idea to check your post calibration response with an independent measurement, and not just rely on the simulated response, especially if you're going to be adding filters. Nevertheless, I'm pretty happy with the default post calibration result. In my case, only filters 1 and 6 are used for the default tilt. I'm free to use filters 2-5 to correct some of the issues revealed in REW. I'll try those out next when I have some time.
Overall, the sub checks a lot of boxes for me. 1) It's a sub that can get down to 25 Hz at reasonable SPL; 2) the sub + room correction eliminated the main room mode issue; 3) filters are implemented in hardware so I don't have to run Equalizer APO, which allows me to use the interface's ASIO drivers. It's more elegant and cost-effective than adding a sub + minidsp separately.
can anyone comment on the Subs latency ?
I have ARCx plugin in Ableton Live(sounds great) and can only monitor while mixing - not while tracking as the VST is way behind the beat and such a cpu hog . . .
Sorry my interface only has a single input channel, so I can't measure timing with a loopback.can anyone comment on the Subs latency ?
It's definitely the DSP and/or output stage. It's likely just noisy and not very hi-fi. Disconnecting the XLRs and using the USB input has the same behaviour. It's a high frequency whine that sounds a bit like a CRT tv. Here's another example user complaint: https://forum.ikmultimedia.com/t/iloud-sub-high-frequency-squeal-problem/139Perhaps try testing with another source (CD player, cell phone, etc.) to rule out the cable or the subwoofer input as the problem.
I tried messing with the gain knobs on both the monitors and the sub, and running various calibrations with different combinations of physical gain settings. They mostly sounded the same.I see you had the same issue with the gain as I did. There's a 15dB difference between the monitors and the sub. I lowered the physical gain of the sub so that the monitors had a gain close to 0dB.
And after measuring, I increased the sub's gain a few dB (from the ARC) so that the response was close to +5/6dB (I listen at a low SPL level and "needed" that extra gain on the sub).
this sub simply doesn't have the headroom to mix / playback bass music properly, i moved the sub to a better position (centered directly in the middle of the 2 speakers , configured with and without ARC, i can clip this sub with such a quiet input, when i get the sound balanced and the sub is right on the edge of clipping i cant get above 80dBa@Querkle you are comparing your tiny home setup with massive sounds systems in very big rooms/venues, that is rather weird I guess?
ARC does what it can, but the sub you use is small. Try placing it in another spot and remeasure again. Or add a second sub.
Then what possessed you to buy such a small sub?highly recomend as a sub test, there is a really deep note that can stress subs, this style of mixdown and sub heavy music is 95% of what i play
multiple reasons.Then what possessed you to buy such a small sub?
