RobL
- Joined
- Mar 4, 2021
- Messages
- 1,116
- Likes
- 1,961
Ik Multimedia recently released a very compact sub:
www.ikmultimedia.com
The interesting thing about it is it’s got their ARC built into it and it will correct ANY brand of upstream monitors. Also gives you a bluetooth input.
(Copied from Ik Multimedia website)
iLoud Sub
iLoud Sub is the only subwoofer that automatically calibrates itself and any connected monitors to your room.
Specs
iLoud Sub Specifications
- Type: Ultra-compact studio-quality subwoofer with automatic setup, alignment, and room calibration
- Driver: 6.5" high-performance aluminum woofer
- Acoustic design: DSP-tuned with 2 x 6.5" aluminum passive radiators
- Amplifier type: High-efficiency Class-D
- Total power: 160 W RMS power, 200 W peak
- Frequency response: 25 - 150 Hz @-6 dB
- Crossover Type: Digital
- Crossover frequency range: 50 Hz - 150 Hz
- Max SPL at 40 Hz: 106 dB peak
- Analog input sensitivity: -4 dBu signal generates 90 dB SPL @1 m
- Maximum analog output level: 13 dBu = 0 dBFS
- Connectors: 2 x XLR and 2 x RCA analog inputs, 2 x XLR and 2 x RCA analog outputs, 1 x USB, 1 x power socket
- Supported Bluetooth® audio codec: SBC, AAC
- Supported USB audio input sample rates: 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz
- Full DSP control
- Calibration: Built-in ARC room correction for both subwoofer and satellite speakers
- Output Latency: 1.42 ms
- Control software: ARC X for macOS and Windows
- Power requirement: 100 to 240 V AC, auto-ranging, 50 or 60 Hz, 5 A max
- Operating temperature (non-condensing): from 0 to 45 °C
