wut?I wonder what kind power supply is built-in ( accept 110-240 Voltage ), it have a figure 8 input. No ground ( Earth ). I figure the ES9311 power chip will smooth thing over considering the initial measurement posted.
It it possible to ground it ?I wonder what kind power supply is built-in ( accept 110-240 Voltage ), it have a figure 8 input. No ground ( Earth ). I figure the ES9311 power chip will smooth thing over considering the initial measurement posted.
Need tear down of M500 to understand WUT perhaps, too earwut?
Why not,It it possible to ground it ?
If i want to ground it ( prevent ground loop )i will attach a ifi AC purifier's ground out to a unused RCA socket. Need a banana to male rca solid core cable.It it possible to ground it ?
Re-wut?If i want to ground it ( prevent ground loop )i will attach a ifi AC purifier's ground out to a unused RCA socket. Need a banana to male rca solid core cable.
The other unused rca perhaps to a ground box
What to expact from that ? any performance concern ?Woow ! There is not voltage buffer/filter after I/V conversion. There is only RCA summing op-amp. Two op-amps are missing for XLR output if I see fit.
Probably imd hump and extra other modulations. I suspect the near 1khz modulations are caused by it.What to expact from that ? any performance concern ?
Unless there is no I/V conversion because the DAC is used in voltage mode. It was possible with the 9018, I don't know for this one.Woow ! There is not voltage buffer/filter after I/V conversion. There is only RCA summing op-amp. Two op-amps are missing for XLR output if I see fit.
Here is es9038Pro. Indeed, you are right, we do not know if the output is in current or voltage.Unless there is no I/V conversion because the DAC is used in voltage mode. It was possible with the 9018, I don't know for this one.
Available on Amazon now with Prime shipping, https://www.amazon.com/dp/B07X6CF4V...&colid=3ZXOMS5DWXNJ&ref_=lv_ov_lig_dp_it&th=1
Still gonna wait for Amir to review this, and for Drop to maybe have it cheaper, since I really don't need it, but I am weak, lol.
3rd supply always around these companyIs SMSL and Sabaj the same company? The display looks identical to the D5 from the pictures...
Good to hear, that someone got it already ! Question: If you will able to test it, RCA and XLR out goes / working in parallel ? In the menu i did not see any option to choose, so I think it supplies both.Already received SMSL M500 today and so far sounds better then my old AVR as headhones (AKG 712 PRO) goes.
Power amp (Loxjie A10) got delayed so could not test with speakers but planing to take old Marants CR502 DAB from other room to test it later on.
Quite surprising was delivery as it took about week to expedite but delivery itself was next day (Shipped Sunday, Delivered Monday) which is no small feat from HK to Czech Republic by DHL.
You are right there is only "HP Out" and "Line out" option in menu so it must use both RCA and XLR at same time.Good to hear, that someone got it already ! Question: If you will able to test it, RCA and XLR out goes / working in parallel ? In the menu i did not see any option to choose, so I think it supplies both.
