Could use a bit more power in the HP stage. Got no juice for my pair of Mr Speakers Mad Dog
I dont know your headphones but this sound just weird.Another observation is that RCA Line out from SMSL M500 does not have enough juice for my JDS Atom, maxing the volume in SMSL m500 and also maxing out the volume of JDS Atom, in normal gain, is giving me no joy when compared to Topping D50s. Using high gain on JDS Atom is still not bumping the volume high enough. Clearly voltage output of D50s via RCA is superior is what this leads me to believe. May be this unit is meant to be used via XLR only?.
Weird, I think maybe you have issue in you PC. Check the sound level at you PC and maybe you should try exclusive mode in your PCAnother observation is that RCA Line out from SMSL M500 does not have enough juice for my JDS Atom, maxing the volume in SMSL m500 and also maxing out the volume of JDS Atom, in normal gain, is giving me no joy when compared to Topping D50s. Using high gain on JDS Atom is still not bumping the volume high enough. Clearly voltage output of D50s via RCA is superior is what this leads me to believe. May be this unit is meant to be used via XLR only?.
From the op-amplifier stage which it share with Headphone amplifier also (another stage of amplifications for the headphone )Hi, can anybody proof my assumption, I don't know if it is possible to regulate volume from XLRs outputs? i.e. are XLRs have output from amplifier or pre-amplifier?
wait, so the headphone output volume controls the xlr output volume and the preamp volume only controls the single ended rca output?From the op-amplifier stage which it share with Headphone amplifier also (another stage of amplifications for the headphone )
Thx, found it in manual just as posted and its working.press C before you try any other buttons. it makes no sense, but it's an SMSL thing with their dacs.
So what in the end, XLRs are output from amplifier and RCAs are output from pre-amp?wait, so the headphone output volume controls the xlr output volume and the preamp volume only controls the single ended rca output?
What is this - "op-amplifier"? I would say that both 6,5mm and XLRs in this case are outputs from amplifier and it is balansed two OPA1612 just 6,5mm has un-balanced wiring but from the same amplifier.op-amplifier stage which it share with Headphone amplifier
I don't think the XLR will have the output to drive headphoneWhat is this - "op-amplifier"? I would say that both 6,5mm and XLRs in this case are outputs from amplifier and it is balansed two OPA1612 just 6,5mm has un-balanced wiring but from the same amplifier.
I ordered M500 and waiting delivery, want to wire my balanced headfone to XLRs cus don't want to use stereo 6,5 output.
I assume, volume can be adjusted on headphone output and RCA/XLR output separately as it was advertised by SMSL. Since on both line outputs (RCA and XLR) you can have signal in the same time, sounds logical that you will adjust it also both together. But someone can confirm / refuse this, who has already a nice M500 on hand.which volume controls affect which outputs?
My M500 comes soon. Ok It is possible to adjust volume on XLR too but not possible to use XLRs output direct to headfones? Because mine planars have 50 Ohms, I don't have to use XLR output without external amplifier right?I assume, volume can be adjusted on headphone output and RCA/XLR output separately as it was advertised by SMSL. Since on both line outputs (RCA and XLR) you can have signal in the same time, sounds logical that you will adjust it also both together. But someone can confirm / refuse this, who has already a nice M500 on hand.
