Zek
- Joined
- Feb 17, 2018
- Messages
- 1,609
- Likes
- 2,175
I think so too.I believe the usb port is for updates
It's not just about a matter of beliefs. Some of us own the unitI think so too.
SMSL A300 Hi-res Power Amplifier 165W
What are the supported Bluetooth codecs?Bluetooth 5.0
I think that the corresponding codecs were only SBC and AAC like AO200, and there was no APTX. If so, SMSL will make it clear and advertise it.What are the supported Bluetooth codecs?
With just SBC & AAC and 80 watts at 8 ohms, if it measure wells, it would be 4 times cheaper than the Rotel A11 Tribute or 8 times cheaper than the Rotel A14 mkii! (Both of which I have been eyeing for the reviews and 5 year warranty.)I think that the corresponding codecs were only SBC and AAC like AO200, and there was no APTX. If so, SMSL will make it clear and advertise it.
The BT of the SMSL amplifier is a bonus function, and the BT with an advanced codec is installed in the DAC.
No break-in required. It will be in tip top shape when new.Do we need to break in the amp?
Do a blind listening test comparison.i feel i miss the depth of the soundstage, in compare to my old amp (Nuforce STA2000 that gets very bad review and measurements here). Anyone geys the same impressions?
If you want a deeper sound, try turning on the EQ SDB.I got the amp from Amazon US for a couple of days. It is my 1st Class D amp. I have read a lot of good reviews of SMSL DA9, SMDL AO2000, Sabaj 20a that are used Infinion chip. This one is just released in June, different Infinion chip and has more power.
Do we need to break in the amp? What is the volume should i set for the amp? Is 60 max? It seems it has a lot of power. Right now i set the amp @56 and my Oppo 205 @ 15 ( for Oppo 205, max is 100 and i never go more than 45 with my old amp), and it sounds loud enough for me. Btw my speakers are Infinity 363. My plan to buy is to drive the JBL530. Definitely i dont think i need 2 to drive my speakers.
Initial listening impression is good, but i feel i miss the depth of the soundstage, in compare to my old amp (Nuforce STA2000 that gets very bad review and measurements here). Anyone geys the same impressions?
I bought an SMSL A300 on Amazon Italy on June 27, 2022, but unfortunately they were not available, and I'm still waiting for Amazon to ship my order, today maybe they send me the order because the product is available again, I don't know if it's on Amazon wrote with you, if this SMSL A300 is really good and sounds like my SMSL AO200 but with more power, I will give you a nice review on Amazon Italy. And then I will also buy another one to connect in BTLThere are prime days sale on the a300 now, don't missed the discount.SMSL A300 Hi-res Power Amplifier 165W*2 BTL Mode Bluetooth 5.0
SMSL A300 Hi-res Power Amplifier 165W*2 BTL Mode Bluetooth 5.0 Support Passive Speakers & Active Subwoofers With Remote Control Input:RCA,BT,USB THD+N:0.004% SNR:103dB ChanneL separation:85dB Cutoff frequency (in high pass mode):50Hz Input Sensitivity / Input Impedance:28OmV/22kΩ Output Power...hifi-express.com
On Polish Amazon already sold out. Great priceThere are prime days sale on the a300 now, don't missed the discount.
Do you notice in BTL mode one channel playing slightly louder ? My left channel was noticeably louder playing through my speakers. About 3-4 db approx. I used a db meter to test it. I has to turn the volume 4 steps / notches louder on the volume control for the right channel.I tried a master-slave connection, but it is difficult to control the volume. The interlocking operation is strange and I can't understand it well. I feel that the sound quality is not good either.
After all, I stopped the master-slave method that uses the BTL-R output and used the two A300s as independent BTL operations.
procedure
1. Turn off the power switch on the back of the two A300s.
Disconnect the BTL-R connection cable. There is no change in the speaker connection. Is the same.
2. Connect the R-ch of the audio output cable from the DAC etc. to the L-ch of IN1 of the first A300, and connect the L-ch to the L-ch of IN1 of the second A300.
If there are other connected devices, connect them to IN2 L-ch in the same way.
3. Turn on the power of the two A300s.
4. Set the amplifier operation to br1 in BTL mode.
5. Set the input mode to IN1.
6. Set the volume to the same level for both units. Subsequent adjustments are operated with the remote control.
The response of the remote control is good, and the volume of the two A300s and the items in the MENU work smoothly in tandem. It is very comfortable to be able to set two A300s at the same time with one remote control operation. Of course, the power can be turned on and off at the same time with the remote control.
Of course, BT and USB cannot be used in BTL mode.
When the A300 is in BTL mode, it is only used for one channel.Do you notice in BTL mode one channel playing slightly louder ?
Are you using SMSL's Master-slave method?Do you notice in BTL mode one channel playing slightly louder ? My left channel was noticeably louder playing through my speakers. About 3-4 db approx. I used a db meter to test it. I has to turn the volume 4 steps / notches louder on the volume control for the right channel.
I switched back to the BTL Master-slave method and everything is working ok now. I hooked it up to a dedicated preamp and use that for the volume control as the volume control in BTL mode when using A300 is a little wonky.Are you using SMSL's Master-slave method?
I first set the BTL method with the Master-slave method, but after I was wondering about the volume control, I changed the R-ch L-ch that does not use the BTL-R to an independent method.
The setting method is as follows.
New SMSL A300 BTL Class-d Power Amp
Immediately after purchase, the sound quality is very high resolution, transparent and smooth, which is my favorite sound quality. I switched to the A20a 2022 and compared it, but the sound quality is very similar and I can't clearly distinguish it. Let's see how it changes over time. Any...www.audiosciencereview.com
I still don't fully understand how the A300 works in BTL mode, but I think it's better to adjust the volume control on the connected external device.I switched back to the BTL Master-slave method and everything is working ok now. I hooked it up to a dedicated preamp and use that for the volume control as the volume control in BTL mode when using A300 is a little wonky.
Is it better to use a preamplifier?I still don't fully understand how the A300 works in BTL mode, but I think it's better to adjust the volume control on the connected external device.
can you tell me what kind of preamp do you use?I switched back to the BTL Master-slave method and everything is working ok now. I hooked it up to a dedicated preamp and use that for the volume control as the volume control in BTL mode when using A300 is a little wonky.
Sounds really strange. You mean your volume issue happened only when in Independent BTL mode?? And is back to normal when in Master-Slave BTL Mode??I switched back to the BTL Master-slave method and everything is working ok now. I hooked it up to a dedicated preamp and use that for the volume control as the volume control in BTL mode when using A300 is a little wonky.
