What is the claim about the maximum power of individual amplifiers based on?
SMSL AO100 (MA12070)
Foshan ShuangMuSanLin electronics Co., LTD. founded in 2009 which located in Shenzhen, China. And our branch company VMV Technology(HK) Company Limited registered in HK in 2013. Our company is specialized in the audio DAC, stereo headphone amplifier, power amplifier, and with own R&D...
www.smsl-audio.com
"Output power: 70W x2 (4 Ohm)"
SMSL AO200 (MA12070 x2)
www.smsl-audio.com
"Output power: 90W x2 (4 Ohm)"
SMSL A300 (MA5332MS see below)
www.smsl-audio.com
"Output power stereo: 165W x2 (4 Ohm)"
Loxjie A30 (MA12070)
DAC,AMP,Headphone AMP,
www.loxjie-audio.com
"Output power: 80W x2 (4 Ohm)
Statements ...
SMSL AO100 Hello to all friends of ASR, as I like to buy these class D mini amplifiers at a really affordable price and I love to try and test them I would like to do a little review of my experience with this very small SMSL AO100 class D amplifier, sorry for mine English, but I'm Italian...
www.audiosciencereview.com
Thread name "SMSL AO100 Amplifier Class D "Subjective review"
At some time: "Ok, so I'm intrigued by these little amps, and their bigger brothers, and curious if anyone has used them on large floor standing speakers that are fairly efficient."
And the answer to that: "SMSL A300 is much more powerful and works much better, but costs 215 euros, but drives floor loudspeakers better". And in addition to that "SMSL A300 I use it with my PC station and with these speakers + sub you are seeing on the photo.
SMSL AO100 I use it with the TV I have in another room and I listen to movies and listen to the sound when I play with the Playstation. , with other small speakers + sub".
Does this amp have auto-standby? What's power consumption in standby mode and in normal mode but when nothing plays?
And that: "The amplifier chip used in SMSL A300 is not MA12070. The A300 uses the same MURAS MA5332MS chip."
I am very interested in the A300 amp, but about the impressions you reported about the highs, it wasn't clear to me, is the highs uncomfortable? or is it a matter of pairing with the other components? I intend to use this amp with speakers and DAC with a more neutral/laid-back/warm sound (which...
And that one: "On the other hand, the MA5332MS is a little less power efficient, but can output much more power than the MA12070."
These for example.
Volume knob position is not an indication of maximum power. Quite a few factors go into that. One biggest factor is whether the volume knob works in linear scale or exponential scale. Could be the case here.
You are right, of course. Still disappointing.
These are quite low volumes (where the A300 doesn't shine)
Yeah, I do not like to listen (insanely, like causing hearing damage) loud anymore - the stated volume levels above are quite loud, actually. These are for music only. For watching a movie or TV, the volume is a lot lower (11-15 only). More loudness or more dynamic range with music is like "hhhmmmm, very nice, more of it
" for me, but same for movies is like "stop yelling at me!" (I do not like that at all).
Does this mean that the A300 at lower power (quiet listening) is worse.
I don't know. But I don't want to chase the amp above 50% either, because i turned the bass and treble up to full (as a substitute for loudness) and want to avoid clipping at all costs, so as not to endanger either the amp or the speakers.
And i plan to feed the following device into the signal:
Trotz seines kleinen Formats bietet der DSP hervorragende Klangqualität. Die enthaltene Software lässt relevante Einstellungen einfach vornehmen. Jetzt ansehen!
www.steinigke.de
https://alldsp-oem.com/software/
It's like a stripped down miniDSP for only 90 EUR, so I can adjust the speakers to my taste with balance and parametric EQ. And that could sometimes reach -+16 dB. So there must be a lot of performance headroom.
That's why I would like to replace the actually very good Loxjie A30 with a simpler, but at least as powerful amp without DAC (less money), since the SMARD only has RCA inputs (and I operate the Loxjie on my TV, which in turn only has Toslink as a audio output).
Therefore I would like to connect a simple FiiO Taishan D03K DAC:
FiiO Taishan D03K is a pretty cheap DAC that was often recommended online to connect TVs (that now mostly provide only digital audio output) with analogue audio gear. I have one so I thought it might be useful to post my measurements. Cost was 21,99 GBP a few years ago. Here's a few pictures of...
DAC ABX Test Phase 1: Does a SOTA DAC sound the same as a budget DAC if proper controls are put in place? Spoiler: Probably yes.
Then the SMARD.
Then an amp, powerful enough for that equalized signal. Clearly it's not the SMSL A300 (because with 200 EUR it's heavily overpriced for not having that amount of power and without a DAC).
Tomorrow I'll get an SMSL AO100 delivered, which I got for 110 EUR. If it performs the same as the Loxjie A30 (which cost me EUR 185) and the FiiO D03K (19 EUR) shows no audible differences to the A30's DAC, that would probably be a good, cheaper alternative to feed the SMARD.
Then I would have an Amp with a DAC, Bluetooth (aptX), parametric EQ (with Limiter, Crossover and so on, per Channel, in and out), surround DSP (integrated into the AO100) and a remote control for just 210 EUR
... the only thing missing would still be a dynamic range control like night mode for watching tv (espacially) but also that bang-booom-crash effects between dialogues within movies ... rrrr ...
