I received my A300 a few days ago and listened to my Sony SSCS5 speakers and no hiss found. Had a hiss thru my sub, even when no cable attached and plugged in. It's an old cheap sub, so I'm going to replace it anyway. My speakers seem to handle the bass pretty well in the meantime.Anyone experience hiss with their a300? That would be a deal killer for me, if I couldn't immediately return it.
Well, there's very little if I put my ear towards the tweeter like a few inches away. It's utterly inaudible at any normal distance though.Anyone experience hiss with their a300? That would be a deal killer for me, if I couldn't immediately return it.
I just got one and do not hear any hiss. I do have a slight hearing loss at upper frequencies though so maybe I'm not the most reliable source.Anyone experience hiss with their a300? That would be a deal killer for me, if I couldn't immediately return it.
I purchased two A300s, but the noise level is slightly different between the two. However, neither A300 can be heard at a distance of 20 cm from the speaker unit.Anyone experience hiss with their a300? That would be a deal killer for me, if I couldn't immediately return it.
I think that would be fine, as long as the noise does not increase with volume, which might be hard to tell. I like the looks and build quality of the AO200, but decided to go with the A300 as the bridgeable feature is interesting, and it costs a bit less. I'm not sure, but is the AO200 discontinued? though still available from several places?I purchased two A300s, but the noise level is slightly different between the two. However, neither A300 can be heard at a distance of 20 cm from the speaker unit.
Compared to the same SMSL AO200, the A300 has a slightly higher noise level.
My speakers have efficiencies of 89db and 87db. However, noise may become noticeable with extremely high efficiency speakers.
As far as I know there is no input in the A300 that bypasses it's internal preamp so it would offer no advantage to introduce a second preamp. From your setup described above it seems that the obvious route to improve sq would be avoiding the built-in DAC from the PC and introducing an external DAC.Should I buy a pre amp for A300? It sounds great without seperate pre amp or dac. But a seperate pre amp would improve the sound quality?
I use ThinkPad laptop+foobar2000+flac audio files as my source. Connecting A300 via 3.5 to RCA cable. Q Acoustics 3020i speakers.
This is earlier discussed in this thread, maybe those posts are helpful.I just got mine and ordered another. I'm confused about how to set up BTL mode.
Should they both be set to Br1, or only the master?
I have previously explained below how to use two A300s with a BTL connection.I just got mine and ordered another. I'm confused about how to set up BTL mode.
There was a temporary shortage of items on Amazon in Japan, but the AO200 continues to be sold.I think that would be fine, as long as the noise does not increase with volume, which might be hard to tell. I like the looks and build quality of the AO200, but decided to go with the A300 as the bridgeable feature is interesting, and it costs a bit less. I'm not sure, but is the AO200 discontinued? though still available from several places?
Thanks Toku,I have previously explained below how to use two A300s with a BTL connection.
New SMSL A300 BTL Class-d Power Amp
Immediately after purchase, the sound quality is very high resolution, transparent and smooth, which is my favorite sound quality. I switched to the A20a 2022 and compared it, but the sound quality is very similar and I can't clearly distinguish it. Let's see how it changes over time. Any...www.audiosciencereview.com
