Doing a bit of measurements at higher volumes. These measurements are at the MLP (around 2.5 meters from the subwoofer). I always use soft/decoupling feet on all our subwoofers and speakers, and I know there is some debate to the audability of this.
On this prototype I only had hard feet to begin with, and the prototype also has thinner panels and less bracing than the production will have. I always start with "lesser" cabinet models to see how well they work, and then improve over time until it ends up what I'd call over engineered, but not going crazy. I find it interesting to see what is required, many speakers are extremely overbuilt compared to what is needed in reality for an inert cabinet. Anyways, I digress.
As mentioned, I used hard feet, and due to the somewhat underbuilt cabinet, there is significant vibration in the cbainet when you pass say 100dB at the MLP and down in the 10-30hz range. So I replaced them with slightly softer feet (still harder than what will be on the production model).
While the frequency response look the same, there is actually a significant change in the THD. The only change here is the feet.
Hard plastic feet:
Softer rubber feet (still not perfectly adjusted for the weight of the sub):
So relatively similar over most of the frequency range, but from 40-60 especially, it's apparently able to dampen some resonances so much that the THD is cut in half at around 50hz. What frequencies that are dampened and how much will depend on the composition of the feet, and of course what resonances are present. The difference will arguably be less with a better cabinet.
Either way, just a small anecdote implying that how you couple your speakers or subwoofers to the floor might make a small, potentially audible difference.
Anyway, this is with some room gain of course, but 1.9% THD
@100dB/30hz (2.5m distance) with a single sub, so with a Manta system with two of these, you'd probably hoover around 1% THD@100dB for the entire frequency range in-room.
And frequency response still not really showing roll-off before 10hz, will test in a different an larger room soon.
