New Sigberg Audio development thread: The Sentinel - A music oriented reference subwoofer developed for the Manta system.
Fair enough ... how about distortion in the deepest bass?
Will the Sentinel be better? BTW, I assume one can buy the Sentinel on its own, without the Manta (?).
Distortion will be very low within it's linear working area. The goal is also to have advanced limiting so that distortion will be kept low (relatively speaking) no matter what you do. So low distortion will be prioritized higher than absolute maximum SPL.
I do not have the final drivers, the final cabinet or the final amplifier, so I cannot give you any hard numbers.
Yes, it will be possible to purchase the Sentinel individually.
One trick I've seen modern sub designers use is to have dual coils on the driver, butted right next to each other. The second coil adds to the B field at the end of the 1st coil, where it's not linear anymore, essentially extending the constant magnetic field from the 1st coil, up to the Xmax, or as close to it as practical. That way, the coil inductance is constant regardless of travel, reducing distortion of the driver.
Wohoo, sample amplifiers have arrived! :D They were way larger than I anticipated. Looks very promising!
Up and running with the new amplifier now, after some startup trouble (the programming cable was wired incorrectly). :)
Another small detail (preliminary / subject to change): Since the weight will be around 60kg, there will be indentations for better grip when handling under the subwoofer. :)
Are you open to rounding the corners of the sub (e.g., like SVS subs) instead of the traditional sharp, square box shape? Rounded corners make it easier to hold or lift the subwoofer than a sharp, square shape.
"Larger than you anticipated" does not sound good. I would have thought that they should manufacture the amplifier exactly as you designed it ;)
It is an OEM amplifier. :)
Beyond that I did of course know the dimensions in advance, but it was still larger than I pictured.
The current Inkognito and 10D has some roundover, but no, that is not the plan on this or future products. Hopefully you won't be carrying it around that much. :)
Current nearfield response, pretty clean up to 300hz, so it can be crossed over high as well if one would want to do that. :)
Does near-field response approximate anechoic response?
Where would the typical 3-dB point be in room?
Yes, it's relatively close to a freefield / groundplane / anechoic measurement.
F3 in-room will depend on the room. I'd expect it to be below 20hz in a medium room. In my relatively small listening room it's below 10hz currently.
Tolerance check of the drivers, this is the final sample compared to a random test of five of the drivers in the first production batch. The red is the original sample which deviates a bit, while all drivers within the batch are essentially identical (within +/-0.5dB) up to 1000hz+, and they will of course not be used anywhere near that high.
So this looks very good. T/S parameters have also been measured and verified with low tolerances.
For those wondering about the small 250hz bump, this is essentially suppressed in the final product (no EQ applied to fix it):
Weekly(?) development post. We've decided to try using tape instead of glue to assemble the cabinet. :p
At the very least, the basket strongly reminds me of the Eminence LAB 15
This is because the 12-spoke frame is an open-tool frame, which originated with the MTX Audio Thunder8000 series vintage subwoofers from the early 2000's and became available for other use after the Thunder8000 series left production. It is sometimes called the "MTX-style basket" among build houses. For a long time, an 8" or 18" version of this frame didn't exist until another vendor paid to have them tooled; MTX had only tooled the 10", 12", and 15". I have also seen some other variations on this basket.
The 12-spoke basket is very good (although a bit fragile near the ends of the spokes) so it gets a lot of use.
There is a 10-spoke 6.5" version out there somewhere that TC Sounds used for a prototype for a 6.5" midbass frame but I have not been able to find one in commercial use.
The more you know.
Five large pallets of drivers ready to be shipped, will hopefully arrive before Christmas. :)
