Not the DCA E3, right?Unfortunately close back headphones all have intrinsic issues. But they much more easily get decent bass extension.
IMO Hypercloud X is a very colored set, it's worth paying a little extra for AKG K371 och an Shure SRH440 non-A.this is too expensive for a closed back, when i could buy a hyperx cloud alpha for 49 bucks and get ~80% of the sound quality.
$350 for something that has the same build quality of a 560s, its insane.
I thought it was improved even though it looks like the 5 series.this is too expensive for a closed back, when i could buy a hyperx cloud alpha for 49 bucks and get ~80% of the sound quality.
The build quality is significantly better (metal headband, for example).this is too expensive for a closed back, when i could buy a hyperx cloud alpha for 49 bucks and get ~80% of the sound quality.
I probably haven't heard such a stupid statement in my life. Clear you have little to non experience with high quality headphones, in special with closed headphones.this is too expensive for a closed back, when i could buy a hyperx cloud alpha for 49 bucks and get ~80% of the sound quality.
Mind you these are indeed arguably not good value for the money compared to other headphones. Though I probably wouldn't pick hyperx cloud alpha as an example. HD620s are mass produced by a large company. I bought a set of Austrian Audio cans for a good amount but still less than these I think. Though I think the Austrian Audio cans likely have better materials and quality. Personally I would like to support smaller companies if possible. At the same time KPH40 is my most used headphone by far.I probably haven't heard such a stupid statement in my life. Clear you have little to non experience with high quality headphones, in special with closed headphones.
I lowered the clamping force to more pleasant values (3N).I thought it was improved even though it looks like the 5 series.
Looks like it has too much clamp for me.
extended the sliders, but it on a stack of books that stretches the headband (no pads), don't over-stretch too much.
Then, using a hair dryer slowly warmed up the middle part of the headband (not too hot, you don't want to melt the plastic) for 5 mins or so.
Then let it cool off for 10 mins before taking the headphones off. Put the pads back on and check the clamping force again.
Better to repeat the procedure with a bit more stretching than to ruin the headband.
As seal is paramount on this headphone don't make the clamping force too low otherwise seal will become an issue.
Compared to the modded 620S or stock?K371 clamp is a little lower.
www.audioreviews.org
The (average) sensitivity is actually a bit higher than it is at 1kHz exactly because of the weird dip it has just above 900Hz.Sound pressure level (SPL) 110 dB / 1 V RMS
