holbob
My M300SE popped like a mofo when literally anything was changed. PC, normal TV or nvidia shield. Put my Flex back in and all went away again.
The M300 SE should work just fine with your 1122DC. 2.0Vrms is the most common output for home components today; CD/DVD players etc., it is not an outlier.A question from an analog guy. My main source of music is a TT, but these days one must have a digital source, too. Am I missing something, being an ignorant... or whatever: since the RCA output is declared at 2.0Vrms, guess the M300SE won't work with my vintage Marantz 1122DC integrated? Will it extremely overload Marantz's 200mV line input sensitivity (10x higher)? Other then that, what I've read here sounds just fine for my needs (occasional casual listening) and budget. TIA.
Thank you very much for your thorough explanation! Which btw also explains how the 1122DC works nice with my current, now dying (after 5 or so yrs), sabaj da3 USB DAC even turned to maximum. Whose specs are unfamiliar to me, though. May I use this opportunity to ask for a recommendation for a matching streamer, since as of recently I've got an optical internet at home.The M300 SE should work just fine with your 1122DC. 2.0Vrms is the most common output for home components today; CD/DVD players etc., it is not an outlier.
According to Hi-Fi World, many current amps have a 400mV sensitivity, but your 200mV sensitivity used to be the most common and has the benefit of also working with older 1Vrms components. See the discussion here. The actual volume out you get will depend on your source, but remember the relationship between power and volume is logarithmic, so the difference in volume between 200mV and 400mV is extremely small.
I would start out with the SMSL M300 SE in variable audio out mode with the volume turned down. If you can max the M300 SE volume knob without distortion then you could switch the SMSL to fixed line out and just control everything with your Marantz if that is more convenient.
Thanks to the forum, I bought a smsl m300 se DAC. Taking into account discounts and promotions on Aliexpress 11.11, I paid 87 dollars. Gorgeous DAC. Balanced outputs, modern USB chip. Very miniature, jewelry made. It looks premium, more expensive than its price. The firmware is new from the factory. There is a filter. Neither I nor my friends hear any microclicks. In a blind test I included this DAC and Topping dx3pro+. I couldn’t detect any difference in sound. Thanks to your forum and forum members. I buy electronics after visiting this forum. Thank you very much. The best forum to help you choose electronics! Even for pensioners like me and where everyone will help with advice!
After your post I turned on the DAC again. I don't hear micro-clicks. I am 63 years old and my hearing is no longer what it was when I was young. But I invited younger friends to listen. I didn't warn them for micro-clicks. They also did not hear anything abnormal. Maybe I'm doing something wrong? (Should there be microclicks when connecting a computer via USB? Or not only? When and under what conditions should microclicks appear?) I used the USB cable only to test the DAC. In my DAC scenario it is not needed. I'm listening to the Wiim pro stream - optics - DAC - amplifier - acoustics.In this circuit I changed the DAC to Topping dx3pro+. In a blind test, all other things being equal, identical conditions, neither I nor my friends could notice or determine the difference in sound.Just in case ,did you test it?
I mean the microclicks is a real issue.
Maybe you are the lucky boy, but something have to say for people who owned M300SE.
Remember to change the USB cable . Find something better, the original USB cable is TRASH.
The infamous firmware that costs 12e on AEThanks to the forum, I bought a smsl m300 se DAC. Taking into account discounts and promotions on Aliexpress 11.11, I paid 87 dollars. Gorgeous DAC. Balanced outputs, modern USB chip. Very miniature, jewelry made. It looks premium, more expensive than its price. The firmware is new from the factory. There is a filter. Neither I nor my friends hear any microclicks. In a blind test I included this DAC and Topping dx3pro+. I couldn’t detect any difference in sound. Thanks to your forum and forum members. I buy electronics after visiting this forum. Thank you very much. The best forum to help you choose electronics! Even for pensioners like me and where everyone will help with advice!
Cirrus Logic's CS43131/CS43198 does not have a DSD direct mode like AKM and ROHM's DAC chips. The same goes for ESS's DAC chip.Does anybody know how the CS chip in this DAC is handling DSD signal?
I mean for AKM chips there is a DSD Direct mode to bypass the Delta-Sigma modulator, wondering how CS works in this regard
Thank you
