- Joined
- Jul 12, 2024
- Messages
- 2,730
- Likes
- 4,162
Not with bass heavy music. I blew a BMR woofer.The BMR sounds fantastic at 85dB and bass is full and strong.
This AEQ stuff is a long standing approach for high end professional systems. For example, many of the highly praised speakers on this forum like the Genelec all use this feature. It has been in use for a couple of decades by mainstream subwoofer makers like SVS. We just dont talk about it much because it cannot be defeated. It is just in there, doing its thing.Since all of this info is such a major departure from Revel's previous product lines, for me it raises more questions than it answers.
I wonder if this "optional" software equalization is designed to smooth out deficiencies in the new design compromises.
You should call Genelec and complain about their monitors. Or JBL about their best measuring monitors. Or SVS about their subs.Soliciting speaker EQ as a feature by the manufacturer seems stupid to me. Why didn't they just design the crossover correctly to begin with?
I can always add room EQ later. I want the speaker crossover as flat as possible in the original design. Not variable.
I get that some people seek this. I hope the market continues to offer options for such use cases.M105 is OK speaker for a small room or used as a height speaker, but it's awful below 80Hz. Any comparison between M105 and it's replacement should focus on how the low end performs below 100Hz.
You are comparing active speaker systems with Revel speakers which are passive.This AEQ stuff is a long standing approach for high end professional systems. For example, many of the highly praised speakers on this forum like the Genelec all use this feature. It has been in use for a couple of decades by mainstream subwoofer makers like SVS. We just dont talk about it much because it cannot be defeated. It is just in there, doing its thing.
Similarly, JBL does this for many professional speakers like the M2. And the well regarded JBL Sythensis speakers are designed to work with AEQ as well. In these latter two cases, it is not built in but has to be in the signal before getting to the speaker.
TLDR, this has been an area of expertise in the JBL, Harman, Revel family for a long time. I'm glad to hear they are adding it to their new speakers as an option. I hope that they make it easy to use without buying prorprietary hardware.....
The physics of acoustics doesn't know whether the amp is inside the cabinet of the speaker or not.You are comparing active speaker systems with Revel speakers which are passive.
| Spec | C245/R35C | C205 |
| 1-inch tweeter material | Deep Ceramic Composite | aluminum |
| woofer driver, inches & material | 2 x 5.25 Micro Ceramic Composite | 2 x 5.25 aluminum |
| cross-over point, Hz | 1.8 k | 1.7 k |
| nominal impedance, ohms | 6 | 8 |
| sensitivity, dB (2.83V/1m) | 86 | 89 |
| amplifier power range, watts | 15 - 150 | 50 - 120 |
| bi-wire options | no | no |
| mounting points | none | none |
| port placement | rear | rear |
| dimensions, H x W x D; in. (mm) | 7.1 x 23.4 x 10.9 (181 x 277 x 245) | 7.9 x 21 x 11.5 (200 x 532 x 292) |
| weight, lb. (kg) | 35.1 (15.9) | 26.1 (11.9) |
| frequency range, +- 6 dB | 55 Hz to 40 kHz | 62 Hz to ? kHz |
correctSo no JBL M2 for you then?
I do not own main speakers (for my 2.2 system) that are so small that they cannot assert themselves well down to at least 40 Hz.I get that some people seek this. I hope the market continues to offer options for such use cases.
Counter point: Any time I see a speaker with extension below 80hz I cringe. Any serious system I put together is bass managed and that extension is un needed, reduces output, typically allows distortion and compression to happen sooner, and introduces unnecessary compromises for a full range system.
Yeah, except if you've had speakers that extend lower, you'll notice a more seamless sound. I have never had such a seamless "one system" sound with speakers that can barely reach 80 Hz. 60 Hz really does sound better in my experience. No, it isn't ideal from a headroom perspective.I get that some people seek this. I hope the market continues to offer options for such use cases.
My filters are a stand alone mini-box (pre-amp inter-connects to the filter box, inter-connects from the filter box to the main amps and the sub amps and from all the amps to their respective speakers).Yeah, except if you've had speakers that extend lower, you'll notice a more seamless sound. I have never had such a seamless "one system" sound with speakers that can barely reach 80 Hz. 60 Hz really does sound better in my experience. No, it isn't ideal from a headroom perspective.
70 Hz would be a good sweet spot but it has historically not been an option.
I don't know if this is true, but I like to believe it.Yeah, except if you've had speakers that extend lower, you'll notice a more seamless sound. I have never had such a seamless "one system" sound with speakers that can barely reach 80 Hz. 60 Hz really does sound better in my experience. No, it isn't ideal from a headroom perspective.
Not at that price. Let’s wait and see.This is the first major Revel speaker product launch with new ownership in place. It will be very telling. I will be looking closely at whether focus and engineering staff were maintained at previous high levels or if it's now about mass consumption.
Black oak veneer is back? Ugh.
People keep harping on about this, apparently content to ignore that we have already been told why there is no 3-way: they don't sell.2-way MTM center
They don't sell as people buying big towers for LR are content to ignore inferior performance of 2-way and/or smallish centers and end up with asymmetrical LCR soundstage. It is funny that in HT it is well established that center is the most important and busy channel but most people, and manufacturers, completely ignore that right off the bat.No accounting for aesthetic tastes; I think they look nice.
Big box loud speakers in general "don't sell" compared to soundbars or TV speakers, so is your argument that they should just stop making them?No accounting for aesthetic tastes; I think they look nice.
