- Thread Starter
- #81
Here's some specs on the larger bookshelf/M106 replacement, which is the Arcam Radia R25 or Revel Performa4 M146. New model specs are from the Arcam website. M106 specs are from the owner's manual.
The crossover, impedance and sensitivity are lower on the new model.
Handles slightly more power, can use a smaller amp, plays slightly lower than and is about 30% heavier than the M106.
The new one has "a hidden mounting system."
| Spec | M146/R25 | M106 |
| 1-inch tweeter material | Deep Ceramic Composite | aluminum |
| woofer driver, inches & material | 6.5 Micro Ceramic Composite | 6.5 aluminum |
| cross-over point, Hz | 1.7 k | 2.3 k |
| nominal impedance, ohms | 6 | 8 |
| sensitivity, dB (2.83V/1m) | 85.5 | 87 |
| amplifier power range, watts | 15 - 200 | 50 - 150 |
| bi-wire options | yes | no |
| mounting points | yes | none |
| port placement | rear | rear |
| dimensions, H x W x D; in. (mm) | 14.1 x 9.7 x 12.7 (359 x 246 x 323) | 15 x 8.25 x 11 (381 x 210 x 278) |
| weight, lb. (kg) | 24.3 (11) | 18.5 (8.4) |
| frequency range, +- 6 dB | 43 Hz to 40 kHz | 59 Hz to ? kHz |
